[GRASS-windows] using R with windows native installer GRASS 6.3
Luigi Ponti lponti at infinito.it
Wed Jul 23 05:40:29 EDT 2008
Hi Darren,
darren norris wrote:
> Dear all,
> Looking for "getting started" type help.
> I am using GRASS 6.3.0 (windows native installer) on vista. I want to
> run R in GRASS and can't understand how to do it.
I think you can do it the regular way, i.e. adding your R path to the
PATH environmental variable in your C:\GRASS\grass63.bat script.
Fore example, you could add the following line:
    set PATH=C:\Program Files\R\R-2.7.0\bin;%PATH%
to the section of the grass63.bat script which sets paths to utilities
(libraries and binaries) used by GRASS.
It seems to work for me.
Regards,
Luigi
> Can anyone explain how to use R (I have the appropriate packages)
> within this GRASS set up. I have tried typing R into a GRASS command
> line (-accessed from the ADD COMMAND LINE button), nothing. No idea if
> it's connected or not or how to add the code I need, whether the
> command line is working or not.
> Answers for an idiot would be a great help (e.g. push x button then
> type y).
> I have looked through the online docs by Roger Bivand and Markus
> Neetler but can't see any guide for the windows native implementation
> showing how to run R from within GRASS - I have seen code examples but
> not where / how to actually type the code which is my main problem!
> Also can't find any tutorials etc either in GRASS or R online docs (I
> can only access freely available online pdf's -- I'm part of a
> conservation NGO and have no institutional access to journals / books
> etc).
> Many thanks,
> Darren
> grass-windows mailing list
> grass-windows at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-windows
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20080723/c5d778d0/attachment-0001.html
More information about the grass-windows mailing list
