[GRASS-windows] GRASS 6.3.0RC5
Adam Baker adamb924 at gmail.com
Wed Mar 19 18:38:07 EDT 2008
On Wed, Mar 19, 2008 at 3:23 PM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 19/03/08 17:12, Adam Baker wrote:
>  > Hi, thanks for responding.
>  > I do have that file, C:\GRASS\tcl-tk\bin\wish.exe. When I run it a
>  > "console" and a "wish" window pop up.
>  > My grass63.bat file has a line:
>  >    set GRASS_WISH=wish.exe
>  > I made a guess and changed it to:
>  >    set GRASS_WISH=C:\GRASS\tcl-tk\bin\wish.exe
>  > That got me farther: the GRASS startup window appears. However, this
>  > message is printed to the console:
>  > access: Invalid argument
>  > ERROR: LOCATION << C:/GRASS/<UNKNOWN> >> not available
>  > And I get a Tcl-looking pop-up box that reads, "Warning: location
>  > <<UNKNOWN>> at GISDBASE <C:/GRASS> is not a directory or does not
>  > exist." When I close that, nothing seems wrong (but I wouldn't
>  > necessarily know, since this is my first interaction the program).
>  Nothing is wrong, just GRASS telling you that it doesn't have correct
>  information about a location to use, which is normal for a first
>  startup. We absolutely have to fix this as it is scary enough to make
>  people belief something is seriously wrong.
>  You should not see this message again the next time you run GRASS.
>  Moritz
I did get that message multiple times, but it went away after I
changed the "GIS Data Directory" field to C:/GRASS/GIS DataBase.
Thereafter, if I select a "Project Location" and "Accessible Mapset"
and then "Enter GRASS,"  I get the message "Error setting region:
child killed: unknown signal." Then another pop-up window with a
lengthy message ("can't read "parts(w)": no such variable....")
appears. Any idea about that? I can type out the whole thing if
necessary.
Thanks,
Adam
More information about the grass-windows mailing list
