R: [GRASS-windows] failed installation of cygwin and GRASS onwindows XP
Marco Pasetti marco.pasetti at alice.it
Wed Mar 26 17:00:24 EDT 2008
Hi Ljuba,
As you are new to GRASS, I suggest you to test the native binary version:
http://grass.osgeo.org/grass63/binary/mswindows/WinGRASS-6.3.0RC5.1-Setup.ex
e
This release is a Technology Preview of the future GRASS 6.3.0 release. At
the moment it contains *quite* all GRASS 6.3.0 functionalities, and, even if
not *fully tested*, it works very well in its main functions.
Because it's an *easy way* for windows-GRASS, I strongly recommend you to
try it [not only because I'm the official releaser ;-D]... While, in the
future, if you'll decide that the *missing* functionalities in win-GRASS
(respect to 6.2.3 stable release) are very important for your job, you can
always switch to GRASS 6.2.3 cygwin version (even if, in that case, I always
suggest to install a Linux distribution on your machine and use GRASS on
it).
Marco
-----Messaggio originale-----
Da: grass-windows-bounces at lists.osgeo.org
[mailto:grass-windows-bounces at lists.osgeo.org] Per conto di Ljuba Veselinova
Inviato: mercoledì 26 marzo 2008 17.23
A: Glynn Clements
Cc: grass-windows at lists.osgeo.org
Oggetto: Re: [GRASS-windows] failed installation of cygwin and GRASS
onwindows XP
On Wed, Mar 26, 2008 at 5:10 PM, Glynn Clements <glynn at gclements.plus.com>
wrote:
>         Start -> Programs -> Cygwin -> Cygwin Bash Shell
>  It's the black and green "C" icon.
There are several things that have the appearance of a black and green C
icon. I managed to get to Cygwin bash shell by using the desktop shortcut
suggested by the installation. However, that too gives me error message. I
am appending a screen shot.
>  If the X server is running, there will be an X icon in on the
> right-hand side of the task bar. If so, quit it and try again.
>  Also, firewall software can sometimes interfere with the X server.
There is no X icon on the task bar. My firewall is turned off.
Thanks again!
Ljuba
Ljuba Veselinova
Dept of Linguistics, Stockholm University, S-10691 Stockholm, Sweden URL :
http://www.ling.su.se/staff/ljuba/
"We learn by going where we want to go."
 Julia Cameron
More information about the grass-windows mailing list
