R: R: [GRASS-windows] Can Only access GUI, no Command Shell
Ryan Rosario uclamathguy at gmail.com
Sun Mar 30 13:28:16 EDT 2008
Thanks! I think I may have found a bug on Vista. I had to "Run as
Administrator" to get the installer to install the Start Menu shortcuts. In
any case, the installer hangs right before downloading Spearfish data. I get
a second window saying that it is trying to copy a file of size 81 bytes,
but it never completes. I am not sure what file it is, but it causes the
environment to not get set correctly. Entering MSYS and typing grass63
yields a "Command not found" error. The installer finishes the installation,
but that one file never copies.
The installer works *perfectly* on my XPSP2 box! :-)
Thanks!
Ryan
On Sun, Mar 30, 2008 at 10:09 AM, Marco Pasetti <marco.pasetti at alice.it>
wrote:
>  Hi Ryan,
> what you say it's very strange! I actually use line commands in output
> window... you just need to type the command you need and press 'Run' button,
> or, alternately, press 'Run (GUI)' button to run the command using its GUI.
> If you mean, instead, that you need to run Unix-like commands, you need to
> start grass from MSYS console, opening MSYS first from GRASS start menu
> link, and then typing grass63 (+enter) from MSYS shell; this done, you can
> work with both (GUI and MSYS shell), with the advantage in MSYS shell to be
> able to use also Unix-like commands (over GRASS in-line commands).
> I hope to have been clear.
> Regards,
> Marco
> *Da:* Ryan Rosario [mailto:uclamathguy at gmail.com]
> *Inviato:* domenica 30 marzo 2008 18.35
> *A:* Marco Pasetti
> *Cc:* grass-windows at lists.osgeo.org
> *Oggetto:* Re: R: [GRASS-windows] Can Only access GUI, no Command Shell
> Thanks for your response. I installed GRASS using your installer which was
> so much easier.
> I still cannot access the GRASS shell to enter commands. How do I access
> the GRASS shell/command prompt? If I try to enter commands into the Output
> window in the GUI, GRASS cannot find the command.
> Ryan
> On Sun, Mar 30, 2008 at 4:22 AM, Marco Pasetti <marco.pasetti at alice.it>
> wrote:
> >  Hi Ryan,
> > since current releases of winGRASS (with windows installer) contain all
> > needed softwares and libraries, you don't need to install neither ActiveTcl
> > nor MSYS, they are already contained in winGRASS package.
> > To access grass please use only the preinstalled links in GRASS start
> > menu folder (or desktop).
> > I'm preparing a new winGRASS release (RC6) with a new README file,
> > containing more detailed information about winGRASS package; while waiting
> > for the new release, you can temporarily access the document at
> > http://www.webalice.it/marco.pasetti/temp/README.html
> > Regards,
> > Marco
> > *Da:* grass-windows-bounces at lists.osgeo.org [mailto:
> > grass-windows-bounces at lists.osgeo.org] *Per conto di *Ryan Rosario
> > *Inviato:* domenica 30 marzo 2008 8.36
> > *A:* grass-windows at lists.osgeo.org
> > *Oggetto:* [GRASS-windows] Can Only access GUI, no Command Shell
> > Hi,
> > I recently installed native winGRASS 6.3RC5 and when I run grass63.bator grass63 from c:\grass63RC5\bin using the Windows command prompt, the GUI
> > loads, but there is no GRASS command shell anywhere. The cursor in the
> > Windows command prompt just blinks. How can I access the GRASS shell? Am I
> > missing something?
> > I installed ActiveTcl 8.4 as well as MSYS.
> > Thanks,
> > Ryan
> <a href="http://www.spreadfirefox.com/?q=affiliates&amp;id=0&amp;t=180<http://www.spreadfirefox.com/?q=affiliates&id=0&t=180>"><img
> border="0" alt="Get Thunderbird!" title="Get Thunderbird!" src="
> http://sfx-images.mozilla.org/affiliates/thunderbird/thunderbird_large.png"/></a>
<a href="http://www.spreadfirefox.com/?q=affiliates&amp;id=0&amp;t=180"><img
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20080330/521ffcb8/attachment-0001.html
More information about the grass-windows mailing list
