[GRASS-windows] Re: fails on first try
Hanowski, Gregory J gregory.j.hanowski at lmco.com
Mon May 18 12:32:36 EDT 2009
Milton,
Thanks for the feedback.
The default directory structure is different than your example.  I found
wish.exe located in two spots...
c:\GRASS-6-SVN\extrabin\wish.exe
c:\GRASS-6-SVN\tcl-tk\bin\wish.exe
I found the Init.sh file here:
C:\GRASS-6-SVN\etc\Init.sh
I noticed this script in that file:
if [ ! "$GRASS_WISH" ] ; then
   GRASS_WISH=wish
   export GRASS_WISH
fi
I modified it to this:
   #GRASS_WISH=wish
   GRASS_WISH=tcl-tk/bin/wish.exe
   export GRASS_WISH
fi
but got the same error.
I also tried
   #GRASS_WISH=wish
   GRASS_WISH="c:\GRASS-6-SVN\tcl-tk\bin\wish.exe"
   export GRASS_WISH
fi
using forward slashes and back slashes, but same error.
Here is the log.  Maybe somebody can shed some light.
Thank you,
Greg
Welcome to GRASS 6.4.0svn (2009)
GRASS homepage:                          http://grass.osgeo.org/
This version running thru:               Bourne Shell (/bin/sh)
Help is available with the command:      g.manual -i
See the licence terms with:              g.version -c
If required, restart the GUI with:       g.gui wxpython
When ready to quit enter:                exit
GRASS 6.4.0svn (demolocation):C:/GRASS-6-SVN/msys/home/hanowski >
WARNING: Digitization tool is disabled (DLL load failed: This
application has fa                                   iled to start
because the application configuration is incorrect. Reinstalling t
he application may fix this problem.). Detailed information in README
file.
  File "c:/GRASS-6-SVN/etc/wxpython/wxgui.py", line 1645, in <module>
    sys.exit(main())
  File "c:/GRASS-6-SVN/etc/wxpython/wxgui.py", line 1638, in main
    app = GMApp(workspaceFile)
  File "c:/GRASS-6-SVN/etc/wxpython/wxgui.py", line 1560, in __init__
    wx.App.__init__(self, False)
  File
"C:\Programs\GIS\OSGeo4W\apps\Python25\lib\site-packages\wx-2.8-msw-unic
o                                   de\wx\_core.py", line 7935, in
__init__
  File
o                                   de\wx\_core.py", line 7509, in
_BootstrapApp
  File "c:/GRASS-6-SVN/etc/wxpython/wxgui.py", line 1576, in OnInit
    workspace = self.workspaceFile)
  File "c:/GRASS-6-SVN/etc/wxpython/wxgui.py", line 178, in __init__
    self.NewDisplay(show=False)
  File "c:/GRASS-6-SVN/etc/wxpython/wxgui.py", line 1214, in NewDisplay
    auimgr=self._auimgr, showMapDisplay=show)
  File "c:\GRASS-6-SVN\etc\wxpython\gui_modules\wxgui_utils.py", line
82, in __i                                   nit__
    self.Map = render.Map()    # instance of render.Map to be associated
with di                                   splay
  File "C:\GRASS-6-SVN\etc\wxpython\gui_modules\render.py", line 402, in
__init_                                   _
    self.projinfo = self.ProjInfo()
  File "C:\GRASS-6-SVN\etc\wxpython\gui_modules\render.py", line 759, in
ProjInf                                   o
    p = gcmd.Command(['g.proj', '-p'])
  File "c:\GRASS-6-SVN\etc\wxpython\gui_modules\gcmd.py", line 358, in
__init__
    _("Error: ") + self.GetError()))
gui_modules.gcmd.CmdError
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20090518/e73e4bf4/attachment.html
More information about the grass-windows mailing list
