[GRASS-windows] Re: fails on first try
Hanowski, Gregory J gregory.j.hanowski at lmco.com
Mon May 18 15:05:54 EDT 2009
Milton,
Ok, I tried putting those two lines at the bottom of the file.  I did
this three times, one for each path style.  The result was always the
same error as before.
Here is the run log from the last attempt where the last two lines in
the file Init.sh were...
GRASS_WISH="/c/GRASS-6-SVN/tcl-tk/bin/wish.exe"
export GRASS_WISH
Welcome to GRASS 6.4.0svn (2009)
GRASS homepage:                          http://grass.osgeo.org/
This version running thru:               Bourne Shell (/bin/sh)
Help is available with the command:      g.manual -i
See the licence terms with:              g.version -c
If required, restart the GUI with:       g.gui wxpython
When ready to quit enter:                exit
GRASS 6.4.0svn (Spearfish60):C:/GRASS-6-SVN/msys/home/hanowski >
WARNING: Digitization tool is disabled (DLL load failed: This
application has failed to start because the application configuration is
incorrect. Reinstalling the application may fix this problem.). Detailed
information in README file.
  File "c:/GRASS-6-SVN/etc/wxpython/wxgui.py", line 1645, in <module>
    sys.exit(main())
  File "c:/GRASS-6-SVN/etc/wxpython/wxgui.py", line 1638, in main
    app = GMApp(workspaceFile)
  File "c:/GRASS-6-SVN/etc/wxpython/wxgui.py", line 1560, in __init__
    wx.App.__init__(self, False)
  File
"C:\Programs\GIS\OSGeo4W\apps\Python25\lib\site-packages\wx-2.8-msw-unic
ode\wx\_core.py", line 7935, in __init__
  File
ode\wx\_core.py", line 7509, in _BootstrapApp
  File "c:/GRASS-6-SVN/etc/wxpython/wxgui.py", line 1576, in OnInit
    workspace = self.workspaceFile)
  File "c:/GRASS-6-SVN/etc/wxpython/wxgui.py", line 178, in __init__
    self.NewDisplay(show=False)
  File "c:/GRASS-6-SVN/etc/wxpython/wxgui.py", line 1214, in NewDisplay
    auimgr=self._auimgr, showMapDisplay=show)
  File "c:\GRASS-6-SVN\etc\wxpython\gui_modules\wxgui_utils.py", line
82, in __init__
    self.Map = render.Map()    # instance of render.Map to be associated
with display
  File "C:\GRASS-6-SVN\etc\wxpython\gui_modules\render.py", line 402, in
__init__
    self.projinfo = self.ProjInfo()
  File "C:\GRASS-6-SVN\etc\wxpython\gui_modules\render.py", line 759, in
ProjInfo
    p = gcmd.Command(['g.proj', '-p'])
  File "c:\GRASS-6-SVN\etc\wxpython\gui_modules\gcmd.py", line 358, in
__init__
    _("Error: ") + self.GetError()))
gui_modules.gcmd.CmdError
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20090518/a8b2fff0/attachment-0001.html
More information about the grass-windows mailing list
