[GRASS-windows] Re: fails on first try
Hanowski, Gregory J gregory.j.hanowski at lmco.com
Mon May 18 18:25:37 EDT 2009
Milton,
I tried starting with grass64 -gui
and got this message:
WARNING: The wish command does not work as expected!
Please check your GRASS_WISH environment variable.
Use the -help option for details.
Switching to text based interface mode.
If I manually run C:\GRASS-6-SVN\tcl-tk\bin\wish.exe, it gives error
message "This application has failed to start because the application
configuration is incorrect.  Reinstalling the application may fix this
problem."
I uninstalled and reinstalled GRASS.
I accepted all the defaults again when I re-installed
Running again in multiple ways resulted in the same error.
I set the PATH environment variable to include c:\GRASS-6-SVN\tcl-tk\bin
and then reboot the computer.
Same error.
I guess I'll have to give up now.
Thanks for trying to help.
Greg
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20090518/6b017926/attachment.html
More information about the grass-windows mailing list
