[GRASS-windows] Re: Re: Problem with compilation of GRASS 7.0 SVN on Windows 7
Johannes Radinger jradinger at gmx.at
Wed Oct 5 03:02:03 EDT 2011
Hi Helmut,
Thank you for your help. Of course I've to switch into the directory where I want to compile.
In the wiki (http://trac.osgeo.org/grass/wiki/CompileOnWindows) I was just jumping over
the coments on 6.4.1 to the compilation of GRASS 7.0 where it isn't mentioned anymore.
Anyway this problem seems to be solved...
...but probabaly a new one popped up. After typing ./mswindows/osgeo4w/package.sh
nothing really happens, no error but also no GRASS installation. In the wiki it says:
4. Check error.log for any messages and mswindows/osgeo4w/package.log if you're having problems.
But where can I find the error log on my computer (directory) or how can access them to check what
is wrong?
To the add-on installation:
1) Your way of putting the add-on into the trunk and then compile GRASS+Add-on at
once sounds promissing to me
2) Does the wingrass-installer work also on other windows systems beside my own?
There is probably a difference between 32 and 64 bit but any other things I have to consider?
3) This way of your installation of an add-on should actually work on any system where
I want to compile GRASS?
Hopefully I have my first compiled GRASS installation with add-ons on my windows.
I am looking forward to that.
Thank you
best regards
Johannes
> Hi,
>> 5)Then I tried to compile. Therefore I typed as mentioned:
>> but got following problem!!:
>> sh: ./mswindows/osgeo4w/package.sh: No such file or directory
> in the wiki: o
> 3. To compile, type in MSYS console:
> cd /osgeo4w/usr/src/grass-6.4xxx (change to dir of the version you
> downloaded)
> and afterwards
> does this help?
> regarding the addons (building my own wingrass-installer with addons), I
> copy the addon source in the grass-source tree, for example r.stream.*
> in C:\OSGeo4W\usr\src\grass_trunk\raster and adapt the make-file
> C:\OSGeo4W\usr\src\grass_trunk\raster\Makefile by adding the additional
> sub-directory which should be compiled.
> HTH
> Helmut
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20111005/6b80dee7/attachment.html
More information about the grass-windows mailing list
