[Liblas-devel] LAS 1.2 and SRS improvements
Howard Butler hobu.inc at gmail.com
Thu Feb 19 14:37:25 EST 2009
On Feb 18, 2009, at 5:29 PM, Howard Butler wrote:
> On Feb 18, 2009, at 4:48 PM, Michael Rosen wrote:
>>> I think it would be good for us to allow the user to ask what was
>>> activated at compile time.
>> I concur.  Perhaps a static method, "LASSRS::SupportLevel
>> LasSRS::GetSRSSupportLevel();" ?
>>> Please give trunk a test and let me know if you have any troubles
>>> with  it.
>> I'm running into compilation problems using GDAL 1.4.2.
>> gt_citation.cpp, line 281 fails on win32:
>>       osCitation = szName;
>>       if(osCitation[n-1] != '|') //// ambiguous:
>> gt_citation.cpp(281) : error C2666:
>> 'std::basic_string<_Elem,_Traits,_Ax>::operator []' : 3 overloads
>> have similar conversions
>>       with
>>           _Elem=char,
>>           _Traits=std::char_traits<char>,
>>           _Ax=std::allocator<char>
>>       E:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\INCLUDE
>> \xstring(1576): could be 'const char &std::basic_string<_El
>> em,_Traits,_Ax>::operator [](unsigned int) const'
>>       with
>>           _Elem=char,
>> \xstring(1556): or       'char &std::basic_string<_Elem,_Tr
>> aits,_Ax>::operator [](unsigned int)'
>>       with
>>           _Elem=char,
>>       or       'built-in C++ operator[(const char *, int)'
>>       while trying to match the argument list '(CPLString, int)'
>> gt_citation.cpp(518) : error C2370: 'cpl_cvsid' : redefinition;
>> different storage class
>>       gt_citation.cpp(38) : see declaration of 'cpl_cvsid'
>> gt_citation.cpp(518) : error C2084: function 'char *cvsid_aw(void)'
>> already has a body
>> Note that gt_citation.cpp is not in the 1.6 version of gdal (latest
>> stable).  The only other non-1.4.2 issue I've had so far is the use
>> of OGR::SetEquarectangular2.  What version of GDAL should we require?
> lassrs.cpp has a copy of the code from gt_wkt_srs.cpp as of about a
> week ago. As a GDAL dev, I track trunk, so I obviously swiped the
> latest and greatest.  If you copy/paste gt_wkt_srs.cpp from your
> version of gdal in the appropriate place in lassrs.cpp, you should
> be able to compile.  Please note that I didn't say it works quite
> yet though ;)  I'm having trouble with libgeotiff's simple keys api
> and ascii geotiff keys.  I think it's a bug in libgeotiff, but I
> haven't quite nailed it down yet.
Indeed it was a bug in libgeotiff.  libgeotiff wasn't appropriately
calculating a string size in ST_SetKey, which was causing things to
blow up.  libgeotiff has been fixed upstream, but this means we now
require a very recent, unreleased libgeotiff to do anything with SRSs
for libLAS :(
> Ideally, I'd like to make whatever Debian would support (please let
> me know Hamish) as the required version, but I'm flexible.  Maybe we
> should just nab gt_wkt_srs.cpp entirely whole instead of embedding
> it in lassrs.cpp so it is easy to swap out with whatever GDAL
> version is desired (or using GDAL's versions directly could work,
> but since the functions we're using aren't part of any sort of
> public API, that proposition is not as desirable).
r1053 pulls gt_wkt_srs.cpp into its own file so that it should be easy
to swap out with a version that matches whatever GDAL version you are
operating with.  You might need to remove the CVS_ID stuff at the top
of the file to get it to compile, however.
More information about the Liblas-devel mailing list
