[Liblas-devel] lasinfo, las2las, las2txt with no argument bombs
Eric Goddard egoddard at memphis.edu
Thu Feb 24 09:43:55 EST 2011
Hi Peder,
I think lasinfo is used to summarize information about the las files. To get
the version information for liblas, you would use liblas-config --version.
Hope this helps.
Eric
On Sun, Feb 20, 2011 at 4:10 PM, Peder Axensten <Peder.Axensten at slu.se>wrote:
> I've just installed liblas 1.6 with tools. When I use libinfo with no
> arguments (I wanted to get the version info) it got a memory issue:
> $ lasinfo
> Input LAS file not specified!
>    lasinfo (libLAS 1.6.0 with GeoTIFF 1.3.0 GDAL 1.8.0 LASzip 1.0.1)
> lasinfo options:
> lasinfo(21384) malloc: *** error for object 0x7fff70717500: pointer being
> freed was not allocated
> *** set a breakpoint in malloc_error_break to debug
>  -h [ --help ]         produce help messageAbort trap
> This does not happen if I give it a file. Same thing with las2las, las2txt,
> but not with the -old variants.
> Is this a known issue?
> Best regards,
> Peder Axensten
> Research engineer
> Swedish University of Agricultural Sciences
> Dept. of Forest Resource Management
> Forest Remote Sensing
> Skogmarksgränd
> se-90183 Umeå
> Sweden
> Phone: +46-90-786.8500
> http://www.srh.slu.se/rsl
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110224/9eb8789f/attachment.html
More information about the Liblas-devel mailing list
