[Mapbender-commits] r3599 - in trunk/mapbender/resources/locale: .
es_ES es_ES/LC_MESSAGES
svn_mapbender at osgeo.org
Thu Feb 26 15:49:09 EST 2009
Author: astrid_emde
Date: 2009-02-26 15:49:09 -0500 (Thu, 26 Feb 2009)
New Revision: 3599
Added:
trunk/mapbender/resources/locale/es_ES/
trunk/mapbender/resources/locale/es_ES/LC_MESSAGES/
trunk/mapbender/resources/locale/es_ES/LC_MESSAGES/Mapbender.po
new translation
Added: trunk/mapbender/resources/locale/es_ES/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/es_ES/LC_MESSAGES/Mapbender.po (rev 0)
+++ trunk/mapbender/resources/locale/es_ES/LC_MESSAGES/Mapbender.po 2009-02-26 20:49:09 UTC (rev 3599)
@@ -0,0 +1,308 @@
+# SOME DESCRIPTIVE TITLE.
+# Copyright (C) YEAR THE PACKAGE'S COPYRIGHT HOLDER
+# This file is distributed under the same license as the PACKAGE package.
+# FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
+msgid ""
+msgstr ""
+"Project-Id-Version: PACKAGE VERSION\n"
+"Report-Msgid-Bugs-To: \n"
+"POT-Creation-Date: 2009-01-27 22:30+0200\n"
+"PO-Revision-Date: 2007-07-29 22:32+0100\n"
+"Last-Translator: Adrian Gonzalez <gonzalez at rapideye.de>\n"
+"Language-Team: IT <LL at li.org>\n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=UTF-8\n"
+"Content-Transfer-Encoding: 8bit\n"
+#: printPDF.conf:13
+msgid "Download: Map as PDF..."
+msgstr "Download: Mapa en formato PDF..."
+#: printPDF.conf:26
+msgid "print legend"
+msgstr "imprime referencia"
+#: printPDF.conf:30
+msgid "Legend"
+msgstr "Referencia"
+#: printPDF.conf:31
+msgid "powered by Mapbender"
+msgstr "powered by Mapbender"
+#: printPDF.conf:60
+msgid "Print preview"
+msgstr "Print preview"
+#: printPDF.conf:63
+msgid "Scale 1:"
+msgstr "Escala 1: "
+#: printPDF.conf:64
+msgid "Date"
+msgstr "Fecha"
+#: printPDF.conf:66
+msgid "Notes"
+msgstr "Notas"
+#: printPDF.conf:73
+msgid "This copy has been automatically generated and is thus not valid without signature."
+msgstr "Esta copia ha sido automaticamente generada por lo que no es valida sin firma."
+#: printPDF.conf:74
+msgid "This copy is protected by law (Par. 3 Abs. 1 VermKatG NW). It can be duplicated, modified, published or be passed to third parties only in agreement with"
+msgstr "Esta copia esta protegida por ley (Alemania, § 3 Abs. 1 VermKatG NW). Cualquier copia, modificacion, pubblicacion o cesion de posesion a terceros puede hacerse solo con autorizacion de"
+#: printPDF.conf:75
+msgid "the publisher, except duplicates and modifications aimed at internal use of government agencies or private use."
+msgstr "del publicista, a excepcion de duplicaciones y modificaciones para uso interno de agencias guvernamentales o uso privado."
+#: printPDF.conf:
+msgid "This copy is protected by law (Par. 3 Abs. 1 VermKatG NW)."
+msgstr "Esta copia esta protegida por ley (Germania, Par. 3 Abs. 1 VermKatG NW)."
+#: printPDF.conf:
+msgid "It can be duplicated, modified, published or be passed to third parties only in"
+msgstr "Copia, modificacion, pubblicacion o cesion de posesion a terceros puede hacerse solo con autorizacion de"
+#: printPDF.conf:
+msgid "agreement with the publisher except duplicates and modifications"
+msgstr "del publicista, a excepcion de duplicaciones y modificaciones"
+#: printPDF.conf:
+msgid "aimed at internal use of government agencies or private use."
+msgstr "para uso interno de agencias guvernamentales o uso privado del publicista."
+#: printPDF.conf:94
+msgid "Format"
+msgstr "Formato"
+#: printPDF.conf:101
+msgid "Orientation"
+msgstr "Orientacion"
+#: printPDF.conf:102
+msgid "portrait"
+msgstr "vertical"
+#: printPDF.conf:103
+msgid "landscape"
+msgstr "horizontal"
+#: printPDF.conf
+msgid "Quality"
+msgstr "Calidad"
+#: printPDF.conf:
+msgid "Comment"
+msgstr "Commentarios"
+#: printPDF.conf:105
+msgid "Quality: %d dpi"
+msgstr "Calidad: %d dpi"
+#: printPDF.conf:108
+msgid "max."
+msgstr "max."
+#: printPDF.conf:111
+msgid "print"
+msgstr "imprimir"
+#: mod_printPDF.php:
+msgid "No format selected"
+msgstr "Ningun formato seleccionado"
+#: mod_digitize_messages.php:29
+msgid "polygon"
+msgstr "poligono"
+#: mod_digitize_messages.php:30
+msgid "line"
+msgstr "linea"
+#: mod_digitize_messages.php:31
+msgid "point"
+msgstr "punto"
+#: mod_digitize_messages.php:32
+msgid "Not an integer value."
+msgstr "No es un numero entero."
+#: mod_digitize_messages.php:33
+msgid "Not a double value."
+msgstr "No es un numero de punto flotante."
+#: mod_digitize_messages.php:34
+msgid "This field may not be empty."
+msgstr "Este campo no puede estar vacio."
+#: mod_digitize_messages.php:35
+msgid "Failure during form evaluation."
+msgstr "Error en el formulario."
+#: mod_digitize_messages.php:36
+msgid "An error occured."
+msgstr "Ha ocurrido un error."
+#: mod_digitize_messages.php:37
+msgid "Success."
+msgstr "Accion completada con exito."
+#: mod_digitize_messages.php:38
+msgid "Delete geometry from database?"
+msgstr "Borrar la geometria de la base de datos?"
+#: mod_digitize_messages.php:39
+msgid "Clear list of geometries?"
+msgstr "Borrar la lista de geometrias?"
+#: mod_digitize_messages.php:40
+msgid "Please select an entry."
+msgstr "Seleccione una entrada."
+#: mod_digitize_messages.php:41
+msgid "Save"
+msgstr "Salvar"
+#: mod_digitize_messages.php:42
+msgid "Update"
+msgstr "Actualizar"
+#: mod_digitize_messages.php:43
+msgid "Delete"
+msgstr "Elimina"
+#: mod_digitize_messages.php:44
+msgid "Abort"
+msgstr "Cancelar"
+#: mod_digitize_messages.php:45
+msgid "Fatal error: EPSG mismatch. "
+msgstr "Error: el codigo EPSG no coincide."
+#: mod_digitize_messages.php:46
+msgid "No geometry selected!"
+msgstr "Ninguna geometria seleccionada!"
+#: mod_digitize_messages.php:47
+msgid "add point"
+msgstr "agregar punto"
+#: mod_digitize_messages.php:48
+msgid "cancel editing"
+msgstr "cancelar la edicion"
+#: mod_digitize_messages.php:49
+msgid "add line"
+msgstr "agregar linea"
+#: mod_digitize_messages.php:50
+msgid "finish line"
+msgstr "finalizar linea"
+#: mod_digitize_messages.php:51
+msgid "add polygon"
+msgstr "agregar poligono"
+#: mod_digitize_messages.php:52
+msgid "close polygon"
+msgstr "cerrar poligono"
+#: mod_digitize_messages.php:53
+msgid "move basepoint"
+msgstr "mover punto base"
+#: mod_digitize_messages.php:55
+msgid "Insert basepoint"
+msgstr "Instertar punto base"
+#: mod_digitize_messages.php:57
+msgid "Delete basepoint"
+msgstr "Eliminar punto base"
+#: mod_digitize_messages.php:59
+msgid "clear list of geometries"
+msgstr "Cancela lista de geometrias"
+#: mod_digitize_messages.php:61
+msgid "save / update / delete"
+msgstr "salva / actualizar / cancelar"
+#: mod_digitize_messages.php:62
+msgid "remove from workspace"
+msgstr "remover de la lista"
+#: mod_digitize_messages.php:63
+msgid "remove from database"
+msgstr "eliminar de la base de datos"
+#: mod_digitize_messages.php:64
+msgid "click the first basepoint to close the polygon"
+msgstr "Haga click en el primer punto base para cerrar el poligono"
+#: mod_digitize_messages.php:65
+msgid "Current: "
+msgstr "Segmento actual:"
+#: mod_digitize_messages.php:66
+msgid "Total: "
+msgstr "Longitud total: "
+#: mod_digitize_messages.php:67
+msgid "new"
+msgstr "nuevo"
+#: mod_wfsSpatialRequest_messages.php:33
+msgid "select by rectangle"
+msgstr "seleccionar por rectangulo"
+#: mod_wfsSpatialRequest_messages.php:34
+msgid "select by polygon"
+msgstr "seleccionar por poligono"
+#: mod_wfsSpatialRequest_messages.php:35
+msgid "select by point"
+msgstr "seleccionar mediante punto"
+#: mod_wfsSpatialRequest_messages.php:36
+msgid "select by extent"
+msgstr "seleccionar por extension"
+#: mod_wfsSpatialRequest_messages.php:37
+msgid "open dialogue form"
+msgstr "abrir dialogo"
+#: mod_wfsSpatialRequest_messages.php:38
+msgid "Invalid box!"
+msgstr "Caja no valida!"
+#: /html/mod_treefolder2.php:56
+msgid "Toggles the visibility of this service"
+msgstr "Habilitar esta capa"
+#: /html/mod_treefolder2.php:57
+msgid "Toggles the queryability of this service"
+msgstr "Habilitar la capa para busqueda"
+#: /html/mod_treefolder2.php:58
+msgid "Opens the layer context menu"
+msgstr "Abrir el menu de contexto de la capa"
+#: /html/mod_treefolder2.php:59
+msgid "Opens the WMS context menu"
+msgstr "Abrir el menu contextual de WMS"
+#: /html/mod_treefolder2.php:60
+msgid "Removes the selected WMS"
+msgstr "Eliminar el servicio WMS seleccionado"
+#: /html/mod_treefolder2.php:61
+msgid "Moves the selection up"
+msgstr "Mover la seleccion hacia arriba"
+#: /html/mod_treefolder2.php:62
+msgid "Moves the selection down"
+msgstr "Mover la seleccion hacia abajo"
More information about the Mapbender_commits
