[Mapbender-users] Hyperlink files
Uwe Seher uwe.seher at googlemail.com
Fri Jul 11 04:33:32 EDT 2008
On Thu, 10 Jul 2008 10:36:54 +0200, San_79 <sanmink at hotmail.com> wrote:
> Hi list,
Hi!
> In ArcGis I have a point shapefile in which I stored the path to some
> images
> and pdf documents, so that using the hyperlink tool and clicking on the
> features these files open up in a new window. Is there a way to do
> something
> similar with geoserver/postgis/mapbender?
Yes.
> I exported the shapefile to postgis and when clicking in the mapbender
> GUI
> with the feature info tool I see the path as a text but I would like it
> to
> be a hyperlink...
You need to create an image tag in your template which has the path as
src-Attribute like this (UMN-Syntax):
<img src="[PATH_ATTRIBUTE]">
> ...or even to display the images as a pop-up with a mouseover??
I prefer to use a small preview image and open the whole pic with a click
in a new Window. This looks like:
<a href="[PATH_ATTRIBUTE]" target=_self><img src="[PATH_ATTRIBUTE]"
width="200" heigth="100" alt="[PATH_ATTRIBUTE]"></a>
> What is the easyest way? Can someone give me a hint?
s.o.
maybe you have to make some changes to fit this in your sourounding.
> Many thanks in advance!
> Sandra
Your welcome
Uwe
http://www.gispunkt.de - http://maps.gispunkt.de
More information about the Mapbender_users mailing list
