[mapguide-internals] RE: PATCH: Raster stability fixes, ticket#462
Traian Stanev traian.stanev at autodesk.com
Mon Mar 30 10:49:53 EDT 2009
I was merely offering a lock-less alternative to the patch that was posted to the ticket, which was just a big lock around raster stylization. If there are other, cleaner, solutions we can certainly discuss them once we know what they are.
Before shutting up, let me point out that the big lock inside the provider is not necessary, since the provider already advertises itself as non-threadsafe in its ThreadCapability. If anything it's the caller's responsibility to lock. So if you want to lock, do it from MapGuide.
The refcounting problem needs to be fixed, regardless of any connection pooling fixes -- it's a bug that can be triggered by code other than the connection pooling.
Traian
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Sunday, March 29, 2009 8:24 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] RE: PATCH: Raster stability fixes, ticket#462
I think the work to test out GDAL as a multithreaded provider is
cool, and am personally really interested in trying it out myself
against some of my data sets to see how stable it is.
I have a couple concerns though.  First, given that GDAL is not
guaranteed to be thread safe, I'm worried that this may just
make the problems we are seeing harder to separate from inherent
multithreading problems in the GDAL provider. Second, I worry
that if this is implemented, it will be seen as a solution,
rather than what it really is: a way of masking the underlying
problem in the MapGuide connection manager, similar to the
temporary "big lock" workaround.
Given that Haris has already spent a lot of days on the analysis
of this problem, I think it would be a good idea to determine
the best solution and implement it rather than putting something
that looks like it works (like the previous fix of using a single
pooled connection) in place.
I know that Haris has been experimenting with at least a couple
alternative permanent solutions to this problem, and will be
interested to hear some discussion around them.
Jason _______________________________________________
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
