[mapguide-trac] #405: Installation location other than the default (windows)
MapGuide Open Source trac_mapguide at osgeo.org
Mon Oct 6 11:11:41 EDT 2008
 Reporter:  jnel         |         Owner:
     Type:  enhancement  |        Status:  new
 Priority:  medium       |     Milestone:
Component:  General      |       Version:  2.0.0
 Severity:  major        |    Resolution:
 Keywords:               |   External_id:
Changes (by cgountanis):
  * priority:  low => medium
Comment:
 It would be nice if this was an option right from the installer. Many
 times the local IT has partitions in place and installing to C:\ by
 default is not an option. I know you can change to repo path after the
 fact but why not do the whole thing right from installer with a simple
 browse or change install path option. This is not a huge issue with the
 web extensions only the server as far as I have seen but both would be
 nice to keep the same folder MapGuide\Web and Server. This would make my
 life easier for sure.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/405#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
