[mapguide-trac] #1812: Maestro shp file load cause OutOfMemory Exception
MapGuide Open Source trac_mapguide at osgeo.org
Thu Sep 22 10:56:29 EDT 2011
 Reporter:  captainst    |         Owner:  jng
     Type:  defect       |        Status:  closed
 Priority:  medium       |     Milestone:  Maestro-4.0
Component:  Maestro      |       Version:  2.2.0
 Severity:  major        |    Resolution:  wontfix
 Keywords:  OutOfMemory  |   External_id:
Comment(by captainst):
 I agree with this solution.
 I have tried several available options provided by Maestro, including
 alias, Unmanaged file, and datasource connection. It is very benificial to
 have Mapguide interface with the external sources rather than importing
 all the data inside Mapguide repositories.
 A very simple reason is that when you update the external datasource, the
 work already done remains untouched, especially for layer styling.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1812#comment:9>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
