[mapguide-users] Major Issue with MapGuide Open Source Release 1.0?
Traian Stanev traian.stanev at autodesk.com
Mon Apr 10 08:22:02 EDT 2006
Was there an Error.log -- your zip only contains Access and Admin logs?
The function mentioned by Dr Watson (MgOgcFilterUtil::process_geometry)
would only be getting called if you are making a WFS query with a
spatial filter, so it makes no sense for it to be crashing the server
when it's sitting idle. Were you doing WFS requests by any chance?
Traian
  _____
Sent: Sunday, April 09, 2006 11:26 PM
Subject: [mapguide-users] Major Issue with MapGuide Open Source Release
1.0?
I have been building a website all weekend (for a demo on Tuesday) and I
have encountered a critical problem several times with the MapGuide
service (only solution is to create a package and uninstall - restore my
server back to a previous state before MapGuide).  I installed MapGuide
Release 1.0 with Web server extensions (using all of the defaults with
PHP) on Windows 2000 Server SP4 with Apache and on several occasions the
services shuts itself down and then I receive a error message that
states
"Microsoft Visual C++ Runtime Library
Program: C:\Program F...
This applicaton has requested the Runtime to terminate it in an unusual
way."
The Event Viewer states a Doctor Watson message
"The application, , generated an application error The error occurred on
04/09/2006 @ 21:21:06.125 The exception generated was c0000005 at
address 0115E529 (MgOgcFilterUtil::process_geometry)"
The next message in the event viewer states:
"The description for Event ID ( 0 ) in Source ( MapGuide Server ) cannot
be found. The local computer may not have the necessary registry
information or message DLL files to display messages from a remote
computer. The following information is part of the event: Server
started. ."
Again this is odd as the application was working fine just minutes
before - this usually happens after I have been in Studio for a while.
This occurs after the installation and server have been working well for
hours.  I am beginning to think that maybe the Studio tool is corrupting
something as I have been spending all of my time in this tool and then
viewing the maps in the browser.
I have attached my MapGuide Server logs (zip).  Hopefully the message
daemon does not strip it off.
Ross
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060410/c52fde12/attachment.html
More information about the Mapguide-users mailing list
