[mapguide-users] SHP Files Strike Again
Chris Gountanis cgountanis at mpower-tech.com
Mon Jun 4 14:13:37 EDT 2007
I was playing around with my unmanaged SHP files and now the server just
crashes on zoom. I created a separate unmanaged feature source to see  if it
was faster zoom wise and that seemed to cause the issue. I also edited the
layer to use new feature source with single SHP file and the preview in
Studio works fine. When bring the whole site up with AJAX viewer the issue
shows its face. Is there a reason why or a way to clear cache? I had turned
on SHP cache for pooling tests maybe that caused an issue? I am not sure
what the server is doing but it using 100% resources then crashes on zooms
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070604/da2f2348/attachment.html
