[mapguide-users] Re: Fusion using SVN as stated in Directions (JavaScript Error Fusion is Undefined)
Zac Spitzer zac.spitzer at gmail.com
Thu Aug 14 11:05:50 EDT 2008
you can always file a patch in trac
On Fri, Aug 15, 2008 at 1:03 AM, Rock Beans <rockbeans at gmail.com> wrote:
> Here it is
> http://lists.osgeo.org/pipermail/mapguide-users/2008-July/013652.html will
> this be commited to Fusion SVN soon as well as the other fixes? Seems simple
> enough. Give me access and I will do it :-)
> The Rock
> On Thu, Aug 14, 2008 at 9:14 AM, Rock Beans <rockbeans at gmail.com> wrote:
>> I followed the instructions on
>> http://lists.osgeo.org/pipermail/mapguide-users/2008-July/013637.html and I
>> am not getting the viewer to come up anymore. Was there some major changes
>> that would cause this or what id the fix? I assume I am missing some setting
>> somewhere. Are there updated mapguide templates maybe since the default SVN
>> copy only contains standard and you have to copy over the old. The checked
>> out fusion directory is in the same location as before and the old files are
>> in fusion_old just in case everything should be working right?
>> The reason why I am even doing this is the Save Map function causes
>> Javascript "Access Denied" errors. Is there any information on either of
>> these topics please?
>> Erro info: Error: OpenLayers.String.translate is not a function
>> Source File:
>> http://localhost/mapguide/fusion/templates/mapguide/slate/index.html...
>> Line: 34
>> Does this mean I need to add open layers or something or disable for
>> MapGuide?
>> The Rock
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
