[mapguide-users] Smooth panning on MouseMove (as in Google Maps) an option?
Paul Spencer pagameba at gmail.com
Tue Sep 9 20:20:38 EDT 2008
Yes, this has been a feature from the initial release.  You need to
create a map definition that has fixed base map scales using studio
(at the bottom of the Map editing panel I think) then the AJAX viewer
will use a tiled mode similar to the google approach.
Cheers
Paul
On 9-Sep-08, at 7:03 PM, inspiron2 wrote:
> Hi,
> I just love this MapGuide Enterprise product. Hats off to the
> developers,
> and the community volunteers.
> I was wondering if there is an option to enable smooth panning as in
> Google
> Maps: when you pan around in MapGuide map, it doesn't refresh (i.e.
> draw)
> the new area coming into the view untill you let go of the mouse
> button.
> Since Ajax is at play here, is it an option/possibility to
> continously draw
> the new map area upon mouse move event? May be, it's already an
> option that
> I don't know how to enable...
> If it is not possible, can someone please share with me the reasons?
> Is it
> to save the server from processing load nightmare?
> thanks much.
> View this message in context: http://www.nabble.com/Smooth-panning-on-MouseMove-%28as-in-Google-Maps%29-an-option--tp19403070p19403070.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
