[mapguide-users] migrating resources from 2009 server to 2010
Andy Morsell amorsell at spatialgis.com
Tue May 12 14:52:37 EDT 2009
Steve,
Is there anything wrong with Jackie's approach of loading a 2009 package on
a 2010 site?  That's my preferred method as well instead of having to run
through the below steps.
Thanks,
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Steve Dang
Sent: Tuesday, May 12, 2009 11:42 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] migrating resources from 2009 server to 2010
Hi Nelson,
Below are the complete steps on how to upgrade/migrate to 2010 -just in case
you need them:
1.  Stop the existing MapGuide Enterprise 2009 Server, if it is running. To
do this, open the Services applet. Select "MapGuide Enterprise 2009 Server",
and then select Action > Stop.
2.  Open a DOS window and change to the 2009 RepositoryAdmin directory
"C:\Program Files\Autodesk\MapGuideEnterprise2009\Server\RepositoryAdmin".
3.  In the DOS window, run BackUpOfflineRepositories.bat. Check the output
to make sure there are no errors.
4.  In the DOS window, run RestoreColdBackupRepositories.bat. Check the
output to make sure there are no errors.
5.  In the DOS window, run RecoverRepositories.bat. Check the output to make
6.  Install the Autodesk MapGuide Enterprise 2010 server.
7.  Stop the newly installed server, if it is running. To do this, open the
Services applet. Select "MapGuide Enterprise 2010 Server", and then select
Action > Stop.
8.  Delete the "empty" repositories found at "C:\Program
Files\Autodesk\MapGuideEnterprise2010\Server\Repositories", then copy the
MapGuide Enterprise 2009 repositories found at "C:\Program
Files\Autodesk\MapGuideEnterprise2009\Server\Repositories" to "C:\Program
Files\Autodesk\MapGuideEnterprise2010\Server\Repositories".
9.  In the DOS window, change to the RepositoryAdmin directory "C:\Program
Files\Autodesk\MapGuideEnterprise2010\Server\RepositoryAdmin".
10. In the DOS window, run SetupRepositoryIndices.bat. Check the output to
11. Start your Autodesk MapGuide Enterprise 2010 server.
Steve.
ndow wrote:
> Hi there
> I have data (resources) stored in a mapguide 2009 server that I need to
> copy and move to the 2010 version.  I'm a new user of MapGuide and can't
> make the mistake of deleting or altering the data in the move.  I've
> really only gone through the getting started tutorials and don't know
> which components to use or how to get it done.  ANy info would be
> appreciated.
> Thank you
> Nelson
View this message in context:
http://n2.nabble.com/migrating-resources-from-2009-server-to-2010-tp2866043p
2866137.html
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
