[mapguide-users] malformed syntax error
Jason Birch jason at jasonbirch.com
Fri Feb 12 12:50:13 EST 2010
Can you try adding a junk parameter to the url, like ?me=jo or maybe
even specift the WMS version or something?
Jason
On 2010-02-12, Joanne Cook <j.cook at oxfordarch.co.uk> wrote:
> Dear All,
> I have had to transfer a mapserver wms to work with IIS6 rather than apache.
> I'm then trying to connect to it with MGOS 2.01. Previously the mapserver
> URL (with the map parameter) was wrapped in a cgi file, so I could call it
> from MGOS using the syntax http://mapserver/cgi-bin/mymap.cgi?
> MGOS connected quite happily like that, but with IIS I can't use the same
> approach. I have tried putting the full address of the mapserver wms with
> the map parameter in as the server URL in Maestro but when I try and test
> the connection I get an error that the remote server has refused the request
> due to malformed syntax.
> I have tested the mapserver wms using getcapabilities and getmap requests
> and all seems to be working fine, and I used the instructions on the MGOS
> wiki to create the wms feature source. I'm so unfamiliar with IIS that I
> don't even know where to find the log files to see what request is actually
> being sent. So, basically, how do I get around this issue in IIS6?
> Many thanks for your help
> Jo
> Joanne Cook
> Senior IT Support and Development
> Oxford Archaeology (North)
> 01524 880212
> http://thehumanjourney.net
> Files attached to this email may be in ISO 26300 format (OASIS Open Document
> Format). If you have difficulty opening them, please visit
> http://iso26300.info for more information.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
