[mapguide-users] malformed syntax error
Kenneth Skovhede ks at geograf.dk
Sat Feb 13 04:30:33 EST 2010
Also, you can try these tricks for troubleshooting IIS6:
http://blogs.msdn.com/david.wang/archive/2005/12/31/HOWTO_Basics_of_IIS6_Troubleshooting.aspx
It has the default location for logfiles under "Usefull logs" about a
page down.
Regards, Kenneth Skovhede, GEOGRAF A/S
Jason Birch skrev:
> Can you try adding a junk parameter to the url, like ?me=jo or maybe
> even specift the WMS version or something?
> Jason
> On 2010-02-12, Joanne Cook <j.cook at oxfordarch.co.uk> wrote:
>> Dear All,
>> I have had to transfer a mapserver wms to work with IIS6 rather than apache.
>> I'm then trying to connect to it with MGOS 2.01. Previously the mapserver
>> URL (with the map parameter) was wrapped in a cgi file, so I could call it
>> from MGOS using the syntax http://mapserver/cgi-bin/mymap.cgi?
>> MGOS connected quite happily like that, but with IIS I can't use the same
>> approach. I have tried putting the full address of the mapserver wms with
>> the map parameter in as the server URL in Maestro but when I try and test
>> the connection I get an error that the remote server has refused the request
>> due to malformed syntax.
>> I have tested the mapserver wms using getcapabilities and getmap requests
>> and all seems to be working fine, and I used the instructions on the MGOS
>> wiki to create the wms feature source. I'm so unfamiliar with IIS that I
>> don't even know where to find the log files to see what request is actually
>> being sent. So, basically, how do I get around this issue in IIS6?
>> Many thanks for your help
>> Jo
>> Joanne Cook
>> Senior IT Support and Development
>> Oxford Archaeology (North)
>> 01524 880212
>> http://thehumanjourney.net
>> Files attached to this email may be in ISO 26300 format (OASIS Open Document
>> Format). If you have difficulty opening them, please visit
>> http://iso26300.info for more information.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100213/6d689e57/attachment.html
