[mapguide-users] RE: Fusion Task Pane without session variable
Greg gbneff at cid.utah.gov
Fri Sep 16 16:32:46 EDT 2011
Thanks for the reply.  I had run across your code in an older post but was
unable to get it to work.  Maybe it has something to do with the way I am
putting the task pane into my viewer.  This is in my index.html:
dTasks = new Jx.Dialog({
        label: OpenLayers.i18n('taskPaneTitle'),
        modal: false,
        resize: true,
        horizontal: '50 left',
        vertical: 'bottom -10',
        width: 400,
        height: 680,
        contentId: 'TaskPane'
with this:
showTaskPane();
and this:
var showTaskPane = function () {
    dTasks.open();
Any thoughts?
Thanks,
Greg
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fusion-Task-Pane-without-session-variable-tp6801587p6802079.html
