[mapguide-users] Corrupted .idx files for shp file connections
Steve G stevenlgolden at gmail.com
Fri Jan 23 10:51:21 PST 2015
Do you use any other application to open and/or edit those same shapefiles
(i.e. ArcGIS, etc)?  I have experienced this problem in the past where the
.idx file created by ArcGIS would work perfectly working normal in ArcGIS,
but would not work properly in MGOS.  My only solution was to delete the
.idx file and have MapGuide generate a new one.  Using another file format
is of course workable solution.
-Steve
View this message in context: http://osgeo-org.1560.x6.nabble.com/Corrupted-idx-files-for-shp-file-connections-tp5183383p5183444.html
