[mapguide-users] Corrupted .idx files for shp file connections
GordonL gordon.luckett at arrowgeomatics.com
Sun Jan 25 18:11:08 PST 2015
I have found with some SHP files.  If you create a Thematic Layer or a Filter
that uses a column that either has no data or that particular filter item
does not exist, I get a corrupt idx.
For example, I get a corrupt idx if I theme my roads.shp layer if I have one
item in my thematic layers called "backroads" for road_type if there are no
"backroads" in my shapefile.
I don't know if that helps, but it has fixed those issues in my case.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Corrupted-idx-files-for-shp-file-connections-tp5183383p5183659.html
