[mapserver-commits] r10424 - branches/branch-5-6/docs/en/mapfile
Fri Jul 30 13:13:40 EDT 2010
Author: jmckenna
Date: 2010-07-30 17:13:40 +0000 (Fri, 30 Jul 2010)
New Revision: 10424
   branches/branch-5-6/docs/en/mapfile/map.txt
   branches/branch-5-6/docs/en/mapfile/web.txt
update debugging text (indirectly related to ticket:3135)
Modified: branches/branch-5-6/docs/en/mapfile/map.txt
--- branches/branch-5-6/docs/en/mapfile/map.txt	2010-07-30 04:27:01 UTC (rev 10423)
+++ branches/branch-5-6/docs/en/mapfile/map.txt	2010-07-30 17:13:40 UTC (rev 10424)
@@ -171,7 +171,8 @@
     The DEBUG setting can also be specified for a layer, by setting the DEBUG
     parameter in the :ref:`LAYER` object.
-    For more details on this debugging mechanism, please see :ref:`RFC28`.
+    For more details on this debugging mechanism, please see the :ref:`debugging`
+    document.
     *Debugging with MapServer versions < 5:*
Modified: branches/branch-5-6/docs/en/mapfile/web.txt
--- branches/branch-5-6/docs/en/mapfile/web.txt	2010-07-30 04:27:01 UTC (rev 10423)
+++ branches/branch-5-6/docs/en/mapfile/web.txt	2010-07-30 17:13:40 UTC (rev 10424)
@@ -17,7 +17,7 @@
     ERROR is used.
 ERROR [url]
-    URL to forward users to if an error occurs. Ugly old MapServer error
+    URL to forward users to if an error occurs. Raw MapServer error
     messages will appear if this is not defined
 FOOTER [filename]
@@ -45,8 +45,13 @@
         LEGENDFORMAT "image/svg+xml"
 LOG [filename]
+    Since MapServer 5.0 the recommeded parameters to use for debugging are the :ref:`MAP`
+    object's CONFIG and DEBUG parameters instead (see the :ref:`debugging` document).
     File to log MapServer activity in. Must be writable by the user the web
     server is running as.
+    .. deprecated:: 5.0
 .. index::
     pair: MAXSCALEDENOM; WEB
