[Mapserver-dev] Compiling Python Mapscript
Howard C Butler hobu at iastate.edu
Mon Apr 28 11:42:15 EDT 2003
Oops, I was using the CVS version of mapserver from yesterday afternoon
about 4:00.
I'll try rolling back to 1.3.17
Thanks
Howard
At 09:40 AM 4/28/2003 -0600, you wrote:
>Hi Howard,
>You haven't mentioned which mapscript version.  I am assuming
>mapscript from 3.6.5.  I had success building the 3.6 mapscript
>with SWIG 1.3.11 and gcc 2.95.
>I am currently compiling the development (3.7) mapscript with
>SWIG 1.3.17 and gcc 3.2.  I subscribe to the SWIG list and read
>that SWIG 1.3.18 had problems and have been waiting to see if
>they are fixed in SWIG 1.3.19 before I upgrade.
>cheers,
>Sean
>On Monday, April 28, 2003, at 09:24  AM, Howard C Butler wrote:
>>I'm having trouble compiling mapscript with swig 1.3.19 and gcc 3.2.
>>I am using Norman's distutils script found on the wiki page.  Many
>>deprecated errors are being returned by swig, and gcc reports that it
>>exits with status 1, but there isn't much useful information in the trace
>>(like what is causing it).  I suspect that I'm probably missing a header
>>file, swig is generating bad/unintended code, or my gcc is screwed up.
>>Can anyone refer me to a gcc/swig combination that they were able to
>>successfully get this going with?
>>Thanks
>>Howard
>>_______________________________________________
>>Mapserver-dev mailing list
>>Mapserver-dev at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
>Sean Gillies
>sgillies at frii dot com
>http://www.frii.com/~sgillies
