[mapserver-dev] msautotest viewer utility
Normand Savard nsavard at mapgears.com
Fri Sep 26 11:20:48 EDT 2008
Hi list,
I created a small add-on to the msautotest tests tool created by Frank.
This is a python based script that creates an HTML page to display
actual/expected images side by side to help developers and testers
verify results.  There is a third column of images as well which is made
of the actual and expected images  superimposed on each other.  These
images are switched in alternance by pressing the button just above to
ease  the process of  detecting differences.
You can see a demo at:
http://dev3.mapgears.com/msautotest/pymod/
I hope that this will help msautotest users to be less reluctant to use
this test framework.  Please do not hesitate to comment.
Norm
