[Fwd: Re: [mapserver-dev] Canvas support for MapServer]
Jan Hartmann j.l.h.hartmann at uva.nl
Tue Jan 27 15:58:35 EST 2009
Wow, brilliant, this solves the problem. Just add a few JavaScript
routines in the template to convert the GeoJSON object into Canvas
commands and you are finished. You can process all elements after that
via the GeoJSON arrays and never need any DOM tree (which isn't there
anyway, as Christian Schmidt remarked).
Just one question: how do you get styling information into the GeoJSON
object? GeoJSON allows additional members at any level in a GeoJSON
object, so these could be used to store colors, linewidths etc. Is it
possible to get these parameters from the Layer's Class object into the
template?
Jan
Steve Lime wrote:
> MapServer can output GeoJSON via query calls to the CGI... Here's an example template:
> var csgSites = { "type": "FeatureCollection",
> [resultset layer="sites"]"features": [
>     [feature limit=-1 trimlast=","]{"type": "Feature",
>       "geometry": {"type": "Point", "coordinates": [[shpxy]]},
>       "properties": {
>         "station": "[station]",
>         "long_name": "[long_name]",
>         "short_name": "[short_name]",
>         [item escape="none" name="storet_id" pattern="." format="'storet_id':'$value',"]
>         [item escape="none" name="usgs_id" pattern="." format="'usgs_id':'$value',"]
>         "has_telemetry": [has_telemetry],
>         "has_archive": [has_archive],
>         "has_water_chemistry": [has_water_chemistry],
>         "has_gagings": [has_gagings],
>         "has_photos": [has_photos]
>     },[/feature]
>   ][/resultset]
> You'd pair this with a new-style OUTPUTFORMAT like so:
>  OUTPUTFORMAT
>     NAME json''
>     DRIVER 'TEMPLATE'
>     MIMETYPE 'aplication/json'
>     FORMATOPTION 'FILE=sites.js'
>  END
> Steve
>>>> On 1/27/2009 at 10:25 AM, in message <497F358E.8000908 at uva.nl>, Jan Hartmann
> <j.l.h.hartmann at uva.nl> wrote:
>> Another option would be to use GeoJSON. Is MapServer able to output
>> GeoJSON, or is it going to be? I guess it would be much easier to write
>> a conversion program from GeoJSON to Canvas than from SVG, and I am sure
>> it would be much more efficient.
>> Jan
>> Stephen Woodbridge wrote:
>>> Dan Little wrote:
>>>> I think there is some problems with the Canvas implementations across
>>>> the different browsers.  I've actually done quite a bit of work using
>>>> the Canvas and the exCanvas extension from Google.  While exCanvas
>>>> SAYS it is a 100% implementation for IE there tends to be a number of
>>>> quirks when it comes to actually placing objects in a drawing stack,
>>>> animating them, or simply clearing the canvas at a predictable point.
>>>> Also, I think it would be much more to the benefit to simply have a
>>>> VML output.  A little bit of browser sniffing is easy to do with any
>>>> JS application (or even some server side scripting) and you'd be
>>>> outputting either SVG or VML in that browser's native preferred
>>>> format.  No goofy javascript library required.
>>> I think converting some SVG into the proposed Canvas format would be a
>>> good starting point so we can evaluate the performance. If consuming a
>>> large Canvas file causes the browser to be slow or crash, then it
>>> might not make sense to even consider moving forward with something
>>> like this. It would seem to be a pretty straight forward task if we
>>> can find someone that knows perl, Canvas and svg or is willing to do a
>>> little research.
>>> -Steve W
>>>> ----- Original Message ----
>>>>> From: Brent Fraser <bfraser at geoanalytic.com> To: Jan Hartmann
>>>>> <j.l.h.hartmann at uva.nl> Cc: mapserver-dev at lists.osgeo.org Sent:
>>>>> Tuesday, January 27, 2009 9:07:32 AM Subject: Re: [mapserver-dev]
>>>>> Jan,
>>>>> So your thought is to have MapServer generate something like
>>>>> (hacked from the example on
>>>>> https://developer.mozilla.org/en/Canvas_tutorial/Basic_usage):
>>>>> Sure, it could be done.  One way is to write another output driver
>>>>> for Mapserver.  Another is to use some server-side scripting to
>>>>> ingest Mapserver's SVG and change into JavaScript-canvas code like
>>>>> that above. A performance hit, but at least it would be on the
>>>>> server side, and it might be a good way to prototype the Mapserver
>>>>> driver.
>>>>> Brent
>>>>> Jan Hartmann wrote:
>>>>>> Hi Brent,
>>>>>> First let me say that Canvas support is just an idea; I think it
>>>>>> can be done
>>>>> but whether it is advisable to do so is up to you to decide. I
>>>>> liked the idea because the Canvas element is supported nowadays by
>>>>> most browsers, unlike SVG which needs a plugin. It is also much
>>>>> simpler, so it's easier to use for simple maps, and especially for
>>>>> simple interactive operations like digitizing, or combining
>>>>> server-side with client-side graphics. That's why I would prefer
>>>>> Canvas above SVG, let alone the fact that I much prefer to program
>>>>> in native Javascript above parsing XML. Most of my maps are simple
>>>>> (I would guess that goes for many people here), so SVG is decidedly
>>>>> overkill. The Canvas HTML element also fits nicely in the page
>>>>> layout and can be processed easily by web-editors.
>>>>>> Your suggestion that Canvas could be implemented at the client
>>>>>> side by
>>>>> catching SVG output and transforming it into Canvas directives is
>>>>> certainly viable. That is also Paul Spencer's view in his reply to
>>>>> my email.  Yet I would prefer a server-side approach: it's more
>>>>> efficient (no second parsing of SVG code that had to be generated
>>>>> in the first place), and I think the server-side code can be easily
>>>>> adapted from the SVG driver. Canvas is a very simple format, just a
>>>>> few graphic primitives, more like GD than SVG actually.
>>>>>> Again, I don't know how difficult it would be to add a Canvas
>>>>>> outputformat,
>>>>> and whether it fits at all into the MapServer design philosophy.
>>>>> However, when it could be done, it would give me an a far more
>>>>> easier tool than SVG  to combine server-side and client-side
>>>>> mapping.
>>>>>> Jan
>>>>>> Brent Fraser wrote:
>>>>>>> Jan,
>>>>>>> My interest is in building a (or re-purposing an existing) tool
>>>>>>> for
>>>>> Cartographic Layout, for printing or rendering a graphics format
>>>>> for easy viewing (e.g. PDF).  Steve's comments were about using
>>>>> existing Web formats and syntax to describe the layout, and
>>>>> existing(?) web editors to do the placement/moving of the layout
>>>>> components.
>>>>>>> My (very limited) understanding of the HTML tag is that it's a
>>>>> "container" recognized by the browser, and vector (and raster)
>>>>> graphics are rendered into it using client-side JavaScript.  Sort
>>>>> of the JavaScript equivalent of the SVG format.
>>>>>>> It would be possible to add another output format to Mapserver
>>>>>>> to generate
>>>>> JavaScript code of canvas rendering methods, but a more elegant
>>>>> approach might be to write a small(?) JavaScript module to ingest
>>>>> Mapserver's SVG and render the objects to the canvas.
>>>>>>> Are there some specific features of the direct-canvas-output
>>>>>>> approach not
>>>>> available in SVG that you need?
>>>>>>> Brent Fraser
>>>>>>> Jan Hartmann wrote:
>>>>>>>> Hi folks,
>>>>>>>> A few weeks ago I suggested in a thread about PDF support
>>>>>>>> that Mapserver
>>>>> could perhaps be made to support the new "Canvas" tag. There were
>>>>> no reactions to this, so I don't know if this suggestion is
>>>>> viable/advisable/practicable, or just downright stupid. Can anyone
>>>>> comment? (from
>>>>> http://lists.osgeo.org/pipermail/mapserver-dev/2009-January/008055.html)
>>>>>>>>> I am wondering if MapServer support for the "Canvas" tag
>>>>>>>>> could do what
>>>>> Steve suggests in a more simple way. Originally, only Safari, Opera
>>>>> and Firefox supported this tag to allow (simple) 2D drawing, but
>>>>> recently a surprisingly simple Javascript interface for IE has
>>>>> become available, translating Canvas command to native IE VRML
>>>>> commands. It requires just one single script tag in the web page.
>>>>>>>>> See the tutorial at the Mozilla site at:
>>>>>>>>> and the IE interface (from the Google stables) at:
>>>>> http://excanvas.sourceforge.net/
>>>>>>>>> This is something I have long been looking for. The
>>>>>>>>> graphics are very
>>>>> simple, so the functionality is nothing like PDF or SVG, but I
>>>>> could imagine that a driver for MapServer could fulfill many needs.
>>>>> I can use it already by letting Mapserver generate raw coordinates
>>>>> and catching them with some sort of Ajax, but a separate driver
>>>>> would be very neat of course.
>>>>>>>>> How about it?
>>>>>>>>> Jan
>>>>>>>> _______________________________________________ mapserver-dev
>>>>>>>> mailing list mapserver-dev at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>>> _______________________________________________ mapserver-dev mailing
>> mapserver-dev mailing list
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090127/ba3f2959/attachment-0001.html
