[Fwd: Re: [mapserver-dev] Canvas support for MapServer]
Jan Hartmann j.l.h.hartmann at uva.nl
Tue Jan 27 16:31:51 EST 2009
As an afterthought: wouldn't it be an idea to output this template
directly via the OutputFormat, as a "GeoJSON" Driver type?. In that
case, MapServer would return the GeoJSON object with all dependent
properties directly as an ASCII string. If the calling HTML file had a
line like:
<script
src=http://mapserver.sara.nl/cgi-bin/mapserv?map=testGeoJSON.map&mode=map>
the GeoJSON object would be loaded into the global namespace of the
web-page and could then be processed further. That way you wouldn't need
a template file, you wouldn't have to write separate templates for each
mapping application, and you would have a regular GeoJSON driver, like
GeoServer has. It wouldn't take much programming time too, as far as I
can see.
Jan
Jan Hartmann wrote:
> Wow, brilliant, this solves the problem. Just add a few JavaScript
> routines in the template to convert the GeoJSON object into Canvas
> commands and you are finished. You can process all elements after that
> via the GeoJSON arrays and never need any DOM tree (which isn't there
> anyway, as Christian Schmidt remarked).
> Just one question: how do you get styling information into the GeoJSON
> object? GeoJSON allows additional members at any level in a GeoJSON
> object, so these could be used to store colors, linewidths etc. Is it
> possible to get these parameters from the Layer's Class object into
> the template?
> Jan
> Steve Lime wrote:
>> MapServer can output GeoJSON via query calls to the CGI... Here's an example template:
>> var csgSites = { "type": "FeatureCollection",
>> [resultset layer="sites"]"features": [
>>     [feature limit=-1 trimlast=","]{"type": "Feature",
>>       "geometry": {"type": "Point", "coordinates": [[shpxy]]},
>>       "properties": {
>>         "station": "[station]",
>>         "long_name": "[long_name]",
>>         "short_name": "[short_name]",
>>         [item escape="none" name="storet_id" pattern="." format="'storet_id':'$value',"]
>>         [item escape="none" name="usgs_id" pattern="." format="'usgs_id':'$value',"]
>>         "has_telemetry": [has_telemetry],
>>         "has_archive": [has_archive],
>>         "has_water_chemistry": [has_water_chemistry],
>>         "has_gagings": [has_gagings],
>>         "has_photos": [has_photos]
>>     },[/feature]
>>   ][/resultset]
>> You'd pair this with a new-style OUTPUTFORMAT like so:
>>  OUTPUTFORMAT
>>     NAME json''
>>     DRIVER 'TEMPLATE'
>>     MIMETYPE 'aplication/json'
>>     FORMATOPTION 'FILE=sites.js'
>>  END
>> Steve
>>>>> On 1/27/2009 at 10:25 AM, in message <497F358E.8000908 at uva.nl>, Jan Hartmann
>> <j.l.h.hartmann at uva.nl> wrote:
>>> Another option would be to use GeoJSON. Is MapServer able to output
>>> GeoJSON, or is it going to be? I guess it would be much easier to write
>>> a conversion program from GeoJSON to Canvas than from SVG, and I am sure
>>> it would be much more efficient.
>>> Jan
>>> Stephen Woodbridge wrote:
>>>> Dan Little wrote:
>>>>> I think there is some problems with the Canvas implementations across
>>>>> the different browsers.  I've actually done quite a bit of work using
>>>>> the Canvas and the exCanvas extension from Google.  While exCanvas
>>>>> SAYS it is a 100% implementation for IE there tends to be a number of
>>>>> quirks when it comes to actually placing objects in a drawing stack,
>>>>> animating them, or simply clearing the canvas at a predictable point.
>>>>> Also, I think it would be much more to the benefit to simply have a
>>>>> VML output.  A little bit of browser sniffing is easy to do with any
>>>>> JS application (or even some server side scripting) and you'd be
>>>>> outputting either SVG or VML in that browser's native preferred
>>>>> format.  No goofy javascript library required.
>>>> I think converting some SVG into the proposed Canvas format would be a
>>>> good starting point so we can evaluate the performance. If consuming a
>>>> large Canvas file causes the browser to be slow or crash, then it
>>>> might not make sense to even consider moving forward with something
>>>> like this. It would seem to be a pretty straight forward task if we
>>>> can find someone that knows perl, Canvas and svg or is willing to do a
>>>> little research.
>>>> -Steve W
>>>>> ----- Original Message ----
>>>>>> From: Brent Fraser <bfraser at geoanalytic.com> To: Jan Hartmann
>>>>>> <j.l.h.hartmann at uva.nl> Cc: mapserver-dev at lists.osgeo.org Sent:
>>>>>> Tuesday, January 27, 2009 9:07:32 AM Subject: Re: [mapserver-dev]
>>>>>> Jan,
>>>>>> So your thought is to have MapServer generate something like
>>>>>> (hacked from the example on
>>>>>> https://developer.mozilla.org/en/Canvas_tutorial/Basic_usage):
>>>>>> Sure, it could be done.  One way is to write another output driver
>>>>>> for Mapserver.  Another is to use some server-side scripting to
>>>>>> ingest Mapserver's SVG and change into JavaScript-canvas code like
>>>>>> that above. A performance hit, but at least it would be on the
>>>>>> server side, and it might be a good way to prototype the Mapserver
>>>>>> driver.
>>>>>> Brent
>>>>>> Jan Hartmann wrote:
>>>>>>> Hi Brent,
>>>>>>> First let me say that Canvas support is just an idea; I think it
>>>>>>> can be done
>>>>>> but whether it is advisable to do so is up to you to decide. I
>>>>>> liked the idea because the Canvas element is supported nowadays by
>>>>>> most browsers, unlike SVG which needs a plugin. It is also much
>>>>>> simpler, so it's easier to use for simple maps, and especially for
>>>>>> simple interactive operations like digitizing, or combining
>>>>>> server-side with client-side graphics. That's why I would prefer
>>>>>> Canvas above SVG, let alone the fact that I much prefer to program
>>>>>> in native Javascript above parsing XML. Most of my maps are simple
>>>>>> (I would guess that goes for many people here), so SVG is decidedly
>>>>>> overkill. The Canvas HTML element also fits nicely in the page
>>>>>> layout and can be processed easily by web-editors.
>>>>>>> Your suggestion that Canvas could be implemented at the client
>>>>>>> side by
>>>>>> catching SVG output and transforming it into Canvas directives is
>>>>>> certainly viable. That is also Paul Spencer's view in his reply to
>>>>>> my email.  Yet I would prefer a server-side approach: it's more
>>>>>> efficient (no second parsing of SVG code that had to be generated
>>>>>> in the first place), and I think the server-side code can be easily
>>>>>> adapted from the SVG driver. Canvas is a very simple format, just a
>>>>>> few graphic primitives, more like GD than SVG actually.
>>>>>>> Again, I don't know how difficult it would be to add a Canvas
>>>>>>> outputformat,
>>>>>> and whether it fits at all into the MapServer design philosophy.
>>>>>> However, when it could be done, it would give me an a far more
>>>>>> easier tool than SVG  to combine server-side and client-side
>>>>>> mapping.
>>>>>>> Jan
>>>>>>> Brent Fraser wrote:
>>>>>>>> Jan,
>>>>>>>> My interest is in building a (or re-purposing an existing) tool
>>>>>>>> for
>>>>>> Cartographic Layout, for printing or rendering a graphics format
>>>>>> for easy viewing (e.g. PDF).  Steve's comments were about using
>>>>>> existing Web formats and syntax to describe the layout, and
>>>>>> existing(?) web editors to do the placement/moving of the layout
>>>>>> components.
>>>>>>>> My (very limited) understanding of the HTML tag is that it's a
>>>>>> "container" recognized by the browser, and vector (and raster)
>>>>>> graphics are rendered into it using client-side JavaScript.  Sort
>>>>>> of the JavaScript equivalent of the SVG format.
>>>>>>>> It would be possible to add another output format to Mapserver
>>>>>>>> to generate
>>>>>> JavaScript code of canvas rendering methods, but a more elegant
>>>>>> approach might be to write a small(?) JavaScript module to ingest
>>>>>> Mapserver's SVG and render the objects to the canvas.
>>>>>>>> Are there some specific features of the direct-canvas-output
>>>>>>>> approach not
>>>>>> available in SVG that you need?
>>>>>>>> Brent Fraser
>>>>>>>> Jan Hartmann wrote:
>>>>>>>>> Hi folks,
>>>>>>>>> A few weeks ago I suggested in a thread about PDF support
>>>>>>>>> that Mapserver
>>>>>> could perhaps be made to support the new "Canvas" tag. There were
>>>>>> no reactions to this, so I don't know if this suggestion is
>>>>>> viable/advisable/practicable, or just downright stupid. Can anyone
>>>>>> comment? (from
>>>>>> http://lists.osgeo.org/pipermail/mapserver-dev/2009-January/008055.html)
>>>>>>>>>> I am wondering if MapServer support for the "Canvas" tag
>>>>>>>>>> could do what
>>>>>> Steve suggests in a more simple way. Originally, only Safari, Opera
>>>>>> and Firefox supported this tag to allow (simple) 2D drawing, but
>>>>>> recently a surprisingly simple Javascript interface for IE has
>>>>>> become available, translating Canvas command to native IE VRML
>>>>>> commands. It requires just one single script tag in the web page.
>>>>>>>>>> See the tutorial at the Mozilla site at:
>>>>>>>>>> and the IE interface (from the Google stables) at:
>>>>>> http://excanvas.sourceforge.net/
>>>>>>>>>> This is something I have long been looking for. The
>>>>>>>>>> graphics are very
>>>>>> simple, so the functionality is nothing like PDF or SVG, but I
>>>>>> could imagine that a driver for MapServer could fulfill many needs.
>>>>>> I can use it already by letting Mapserver generate raw coordinates
>>>>>> and catching them with some sort of Ajax, but a separate driver
>>>>>> would be very neat of course.
>>>>>>>>>> How about it?
>>>>>>>>>> Jan
>>>>>>>>> _______________________________________________ mapserver-dev
>>>>>>>>> mailing list mapserver-dev at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>>>> _______________________________________________ mapserver-dev mailing
>>> mapserver-dev mailing list
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090127/ed9acc26/attachment-0001.html
