[mapserver-dev] Vote for MS-RFC-55: Improve control of output resolution
Daniel Morissette dmorissette at mapgears.com
Mon Mar 16 13:46:55 EDT 2009
Paul Spencer wrote:
> how about RESOLUTION and OUTPUTRESOLUTION where RESOLUTION would be
> DEFRESOLUTION as defined in the RFC?
Thought of that one too, but that would mean a change of meaning and
behavior for the existing RESOLUTION keyword. i.e. all apps that
currently use RESOLUTION would need to be adapted to use
OUTPUTRESOLUTION instead (in scripts or in URL params).
OTOH if we add a new keyword such as DEFRESOLUTION then existing apps
continue to pass/set resolution the same way. With the proposed
approach, the only change to existing apps may be to set DEFRESOLUTION
to be the same value as RESOLUTION if they do not wish to have the
symbology scaled, but that would be a very very rare case.
Daniel
Daniel Morissette
http://www.mapgears.com/
