itemquery
b-8 at gmx.de b-8 at gmx.de
Wed Jun 21 22:59:18 EDT 2000
thanx, it worked. I tried
(w|W)(a|A)(c|C)(o|O)(n|N)(i|I)(a|A) instead of Waconia in my
lake search, and it worked ... cool :o)
I'm not familar with regex, so maybe there is a simpler regex out
there to achieve the same (?)
thanx again
	Michael
> Itemquery uses regular expression for determining matches. I hope to
> make itemquery more like expressions in the variety supported. For now
you'd
> have to create case insensitive regex's to send as values for itemquery.
> Should be doable with javascript for
> Itemqueries can easily be mimiced, with much more flexibility, using
> xbase modules of popular scripting languages and a tiny bit of mapscript
if
> necessary.
> Steve
> <<< <b-8 at gmx.de>  6/21  5:02p >>>
> Hi,
> I'm playing around with the itemquery stuff and it works fine
> so far. My only problem at this time is that the text search is case
> sensitive.
> Is there a possibility to tell mapserver to ignore the
> case ?
> thanks in advance
> 	Michael
> Sent through Global Message Exchange - http://www.gmx.net
