Perl/Mapscript and mod_perl ?
Doyon, Jean-Francois
Jean-Francois.Doyon at CCRS.NRCan.gc.ca
Thu Oct 19 17:20:24 EDT 2000
Hmmmm OK, well I'm looking around the SWIG site and not seeing anything, and
there are no patches it seems. Maybe th eproblem was fixed in the current
release ? Do you use the latest release ?
Apache::PerlRun huh ? OK , I'll go take a look at that one ...
As for the reentrancy thing, I haven't heard that word in a LONG time :) Any
chance you could explain what that might mean to me ?
I'm gonna give it a try anyways, just to see ...
Thanks as allways !
J.F.
> From: Stephen Lime[SMTP:steve.lime at dnr.state.mn.us]
> Sent: Thursday, October 19, 2000 4:46 PM
> To: Jean-Francois.Doyon at CCRS.NRCan.gc.ca;
> mapserver-users at lists.gis.umn.edu
> Subject: Re: Perl/Mapscript and mod_perl ?
> It's not a mapserver issue per se. Apparently there are issues with SWIG
> generated code that make unusable with mod_perl. I haven't checked the
> SWIG site to see if this has been fixed or not. There was a patch. Issues
> all have to do with perl internals, nasty stuff.
> In spite of this I've run simple mapscript stuff under mod_perl without
> incident using Apache::PerlRun.
> Note that the map file object is NOT reentrant. It's structures are
> modified during the course of a draw. Nay need a mapObj copy function to
> use under Apache::Registry if the SWIG problems can be overcome.
> Steve
> >>> "Doyon, Jean-Francois" <Jean-Francois.Doyon at CCRS.NRCan.gc.ca> 10/19/00
> 14:15 PM >>>
> Goodday !
> I've been quiet lately, so I came up with a new question :)
> I was wondering if anybody has had experience running Perl/Mapscript
> programs
> using mod_perl through the Apache::Registry module ?
> My main concern is that I vaguely remember hearing about some people
> having
> detected
> memory leaks and so on, presumably from the mapserver module itself.
> This might be a concern since I will be putting the program under HEAVY
> load.
> I plan on implementing under Apache 1.3.14, mod_perl 1.24_01 and Perl 5.6
> If anybody has any experience with a similar setup, I'd love to hear about
> them !
> Thanks,
> Jean-Francois Doyon
> Internet Service Development and Systems Support
> GeoAccess Division
> Natural Resources Canada
> (613) 992-4902
