Mapserver on Win32 - CGI Error
Stephen Clark
spclark at nbnet.nb.ca
Wed Oct 25 12:11:22 EDT 2000
It might be helpful if you tried apache instread of the microsoft server. If you're interested I could send you my setup using Apache ...
Stephen Clark
Geomatics Specialist
Tantramar Planning
----- Original Message -----
From: "Fawcett, David" <david.fawcett at moea.state.mn.us>
To: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, October 25, 2000 11:06 AM
Subject: Mapserver on Win32 - CGI Error
> I am in the process of installing the Win32 port of Mapserver on my home machine so I can work on some of my existing apps there. I installed the 3.011 .exe from DM Solutions, changed all of the paths and URLs in my app, and fired it up.
> The result that I get is a CGI error. It tells me something to the effect that Mapserv has "misbehaved" and not returned a full set of http headers. I can get a direct quote if it would help, but I am now at work. It also gives me a pop-up window with error code text, "stack dump......".
> Any of you with Mapserver Win32 experience have any ideas what could be causing this?
> It is running on Win98, on MS Personal Web Server. Not a particularly robust platform, I know, but I thought that I had seen a post from someone who had successfully run Mapserver on a similar platform.
> Thanks,
> David
> David Fawcett
> MN Office of Environmental Assistance
