Setting up
Lyndon Zimmermann
lyndon.zimmermann at adelaide.edu.au
Fri Oct 27 03:57:59 EDT 2000
Chris: I'll work through your suggestions, thanks.
Anyone: I struck a strange feature. I was trying to understand the
extent object in the .map file so I reduced the minimum values on
Example 2 (a static shapefile), and the map zoomed out. Fine. I changed
them back, clicked reload on Netscape, and it didn't zoom back in. If
I'm not achieving an effective refresh then debugging is going to be
tricky. Any comments?
Lyndon Z
imap at chesapeake.net wrote:
> Lyndon,
> Boy I fought with RedHat 7 for a day or 2 trying to get things
> working with 3 different version of GD on that machine... It is
> difficult to make it find the correct one. I can tell you are
> going thru the same malfunction with your install.
