MapServer and Borland C++
Lyndon Zimmermann lyndon.zimmermann at adelaide.edu.au
Wed Sep 27 20:52:03 EDT 2000
Daniel,
The desire and necessity for UNIX users to compile from source to suit their
particular machine can be accepted as a given, and I presume they all have compilers
with their operating system, making them effectively free.  Windows users typically
don't get the source code and don't compile their applications before use.  A Windows
compiler is relatively big bucks (I think MS VC/C++ is in the order of A$600 full
price) and high complexity - so much for "Open Source".
I suppose I would ask those doing development of Windows compilation to use a free
compiler rather than an expensive one, or forget about the instructions, Makefiles
etc and just distribute the Windows executable.
PS, I do plan to repeat this exercise under Linux, but I'm currently locked into
delivering on NT.
Regards,
Lyndon Z
Daniel Morissette wrote:
> Hi,
> Back to the question of whether MapServer can be compiled with the
> Borland compiler:  I withdraw what I wrote in my previoyus message...
> it's probably not that simple.
> I got the Borland C++ 5.5 command-line compiler (available as freeware
> from the Borland web site in case anyone is interested!) and did a
> couple of quick tests.  Adapting the makefiles was not too bad, but I
> stopped when I started getting errors in the project.h (PROJ.4) header
> file.  Which implies that there would also be work required in some of
> the modules that MapServer uses before we can compile MapServer itself
> with Borland.
> Since it's not a trivial task, I think I'll give up for now.  However,
> I'm wondering if there is enough interest to justify supporting the
> Borland compiler???
>  Daniel Morissette                       danmo at videotron.ca
>               http://pages.infinit.net/danmo/
>   Don't put for tomorrow what you can do today, because if
>       you enjoy it today you can do it again tomorrow.
Lyndon Zimmermann
BE (Mech Adelaide) Grad Dip Bus Admin (UniSA)
Biomass Energy Atlas for Australia Co-ordinator
University of Adelaide Agronomy and Farming Systems
Dir (GISCA) +61-8-8303 3975 Switch (GISCA) 8303 3900 Mob 0414 91 4577
Fax (GISCA) +61-8-8303 3498 email lyndon.zimmermann at adelaide.edu.au
Adelaide Uni Bioenergy Website:
http://www.gisca.adelaide.edu.au/~lzimmerm/uofabioenergy/bioenergy.html
Biomass Energy Atlas Website:
http://sg211.gisca.adelaide.edu.au/bioenergy_atlas/html/atlas_index.html
