MapServer and Cygwin
Eduin Yesid Carrillo yecarrillo at hotmail.com
Thu Apr 5 08:55:04 EDT 2001
Yes I get this kind of error some times. Maybe steve can give some help whit
this.
I've checked my apache error log with :Premature end of script headers.
This error is caused when MS doesn't send the standard HTML header
(Content-type: text/html\n\n)
Then, I use this trick: Start some(or all) of your HTML templates with this:
<html>
<head>....
Note two spaces before <html> tag. If MS is sending the header with some
templates, then you will see "Content-type: text/html" on the top of your
pages. But if doesn't, you will get the correct response ...
I use this trick with MAXTEMPLATE , MINTEMPLATE and ERROR templates.
Ingeniero Civil
CIUDAD DIGITAL
Central de Información Regional Georefenciada
Bucaramanga - Colombia
yecarrillo at condorito.uis.edu.co
#ICQ 14323531
>From: Ma <marin at here.is>
>To: "mapserver-users at lists.gis.umn.edu" <mapserver-users at lists.gis.umn.edu>
>Subject: MapServer and Cygwin
>Date: Thu, 05 Apr 2001 01:09:01 +0000
>Dear All,
>I compiled MapServer (3.4. and 3.3.011.) with Cygwin under Win2000 SP1.
>But when I tried it in the web server I got: "500 Internal Server Error"
>and in the Apache error.log: "Premature end of script headers:
>d:/apache/cgi-bin/mapserv.exe"
>What is the possible reason and how to fix it?
>When I run the script in the shell the result is:
>$ ./mapserv.exe
>This script can only be used to decode form results and
>should be initiated as a CGI process via a httpd server.
>Ma
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
