[mapserver-users] Legend CGI request
Trem Stamp
trem at socialchange.net.au
Tue Dec 18 19:52:08 EST 2001
All,
In the old mapserv versions, it was possible to use the native mapserv cgi syntax to retrieve a legend symbol.
I this also the case with mapserv 3.5? The url below is in WMS, but when I chaange it to make a request in the old format for a legend symbol, the it doesn't work.
http://nccmap-dev.socialchange.net.au/cgi-bin/mapserv?map=mapfiles/ncc.map&WMTVER=1.0.0&SRS=EPSG%3A4202&REQUEST=map&FORMAT=GIF&TRANSPARENT=true&EXCEPTIONS=INIMAGE&BBOX=150.65,-33.95714285714286,151.477,-33.943285714285715&WIDTH=400&HEIGHT=400&LAYERS=bush_rem&STYLES=
When I change syntax to request a legend symbol, then I get an error:
http://nccmap-dev.socialchange.net.au/cgi-bin/mapserv?map=mapfiles/ncc.map&mapext=140.638000+-37.842000+153.962000+-27.857000&mode=legend&&mapsize=400+300&layer=bush_rem
Can someone tell me if this should work, and if not then what the syntax would be?
Cheers,
Trem
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20011219/38ff4d11/attachment.html
