[mapserver-users] LD_LIBRARY_PATH
Stephen Lime
steve.lime at dnr.state.mn.us
Mon Dec 24 12:13:13 EST 2001
The SetEnv belongs in the httpd.conf. Sounds like mod_env was not compiled into the binary so
you'll either need to get one that has that module enabled or compile it yourself.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> <XSun at odu.edu> 12/24/01 09:30AM >>>
Hello Steve and all other friends,
After read all the articles in the list about the LD_LIBRARY_PATH problem.
I am still puzzled with one problem. which file should I modify to add the
following lines.
SetEnv LD_LIBRARY_PATH "/usr/local/lib"
PassEnv LD_LIBRARY_PATH
I tried to add to .cshrc file. But It can not acknowledge "PassENV"
command.
I tried to add to httpd.conf. "SetEnv" is not valid command. By the way ,
my apache server is now a binary installation. I download the source code
, and read the source file of mod_env.c , But I didnot know if I should
modify it and how to modify?
Which files should I modify? .cshrc ? httpd.conf? mod_env.c?
Can someone give me some hint about it?
Thanks a lot.
Have a great holiday and merry christmas to all in the lists!
XSun
