[mapserver-users] MapScript and PHP 4.0.6
Rob Martinson cathode at nichebox.com
Fri Jul 20 13:09:13 EDT 2001
Daniel,
Excellent work. I recompiled with PHP 4.0.6 and the CVS that you just
checked in today and everything is working well so far accessing layers
with Mapscript.
There are a few other minor issues with 3.5 that are unrelated to this.
I was going to check the latest mapserver source into my local CVS
database and start playing a bit with some of these things and see how
much damage I can do. Will be sure to hide my failure and report any
success. :)
Thanks again!
Rob Martinson
Nichebox - http://www.nichebox.com
Development - http://dev.nichebox.com
> -----Original Message-----
> From: owner-mapserver-users at lists.gis.umn.edu
> [mailto:owner-mapserver-users at lists.gis.umn.edu] On Behalf Of
> Daniel Morissette
> Sent: Friday, July 20, 2001 5:30 PM
> To: Rob Martinson
> Cc: 'mapserver-users'
> Subject: Re: [mapserver-users] MapScript and PHP 4.0.6
> Hi,
> A fix for this MapScript vs PHP4.0.6 problem has been
> committed to the MapServer CVS for MapServer 3.5.
> Things seem to be working fine for us now with PHP 4.0.6 and
> MapScript, so please let us know if you notice any more
> problems with this combination.
> BTW, this fix in the latest MapServer 3.5 may result in
> (minor) memory leaks with versions older than PHP4.0.6 since
> our problem was a side-effect of a memory leak fix in
> PHP4.0.6.  So it is recommended that if you compile/install
> the latest MapScript 3.5 from CVS then you also upgrade to
> PHP 4.0.6  Note that the PHP3 version (does anyone still use
> it anyway?) was not affected at all by these problems.
> And BTW, No we won't publish a new 3.4 release with this
> fixed, but if you want to upgrade to PHP4.0.6 with MapScript
> 3.4 then you can add a call to zend_list_addref() after the
> add_property_resource() call in
> phpms_object_init() around line 594 in php_mapscript_util.c:
>   add_property_resource(return_value, "_handle_", handle_id);
>   zend_list_addref(handle_id);
> Best Regards,
>  Daniel Morissette               morissette at dmsolutions.ca
>  DM Solutions Group              http://www.dmsolutions.ca/
>   Don't put for tomorrow what you can do today, because if
>       you enjoy it today you can do it again tomorrow.
> Rob Martinson wrote:
> > Daniel,
> > Thank you thank you! Consider this a confirmation to
> problems with PHP
> > 4.0.6. I backtracked and rebuilt with source from 4.0.5 and I have
> > zero problems! The issues with losing the handle of the map when
> > dynamically generating a map from database contents are gone. I can
> > now reliably (it
> > seems) create a map on a blank .map file using mapscript only to set
> > map/layer/class properties and add additional layers.
> > This works now with the CVS version of Mapserver, Gdal and
> PHP 4.0.5
> > on my end.
> > Rob Martinson
> Behalf Of Daniel
> > > Morissette
> > > Sent: Tuesday, July 17, 2001 7:27 PM
> > > To: mapserver-users
> > > Subject: [mapserver-users] MapScript and PHP 4.0.6
> > > Hi Everyone,
> > > There seems to be an incompatibility between the PHP/MapScript
> > > module and PHP 4.0.6 which causes crashes or odd error
> situations,
> > > most of the time with the
> > > map->getLayer() call.  This happens on both Windows and Unix.
> > > We are going to look into this, but in the meantime, you should
> > > avoid using the PHP/MapScript module with PHP 4.0.6 ...
> you can use
> > > PHP 4.0.4pl1 or 4.0.5 which were both working fine.
> > > Note that backtracking to older versions of MapServers
> such as 3.4
> > > or 3.3.011 with PHP 4.0.6 is not likely to resolve the problem.
