[Mapserver-users] PHP/mapscript, PostGIS, and setFilter
Paul Ramsey pramsey at refractions.net
Mon Dec 9 13:48:55 EST 2002
You could narraw down the potential problem location a little more by
seeing if your string filter works within a mapfile, without using PHP.
If it works in the mapfile, it is PHP/Mapscripts fault, if it doesn't
then it is our fault. :)
P.
Paul Smith wrote:
> Hello all,
> I'm running PHP/mapscript and using PostGIS to store my geography.
> Trouble is, with the setFilter method under a layer, I can use an
> expression that checks for an integer, but not a string value. For example:
> $streets->setFilter("gid = 76");
> works, but
> $streets->setFilter("street = 'S Western'");
> gives me an HTTP 500 error. I've also tried using different combinations
> of single- and double-quotes, like:
> $streets->setFilter('street = "S Western"');
> Nuthin'. Same expression works fine directly under psql. What's up?
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
