AW: [Mapserver-users] Raster layer and Projection
frauke.trurnit at gmx.de frauke.trurnit at gmx.de
Wed Dec 11 05:24:47 EST 2002
Jan,
I've changed the LAYER-STATUS to DEFAULT but nothing happens.
Frauke
NAME "Raster-Stuttgart"
STATUS ON
EXTENT 509900 5410000 520000 5400000
UNITS METERS
#EXTENT 9.1351 48.8274 9.2707 48.7373
#UNITS dd
SIZE 500 500
SHAPEPATH "/www/projects/raster/data/raster/"
IMAGECOLOR 230 230 230
IMAGETYPE GIF
PROJECTION
   "init=epsg:32632"
   #proj=UTM
   #ellps=WGS84
   #datum=WGS84
   #zone=32
   #north
   #no_defs
END
WEB
  TEMPLATE "./raster.html"
  IMAGEPATH "/usr/local/httpd/htdocs/ms_temp/"
  IMAGEURL "http://172.23.71.157/ms_temp/"
END
LAYER
  NAME "Stuttgart-Mairs"
  DATA "stgt_d7517_70pdi.tif"
  TYPE Raster
  STATUS DEFAULT
  PROJECTION
    "init=epsg:32632"
    #proj=UTM
    #ellps=WGS84
    #datum=WGS84
    #zone=32
    #north
    #no_defs
  END
END #layer
END #mapfile
-----Ursprüngliche Nachricht-----
Von: Jan Hartmann [mailto:jhart at frw.uva.nl]
Gesendet: 10 December 2002 19:07
An: f.tr at dds.ptv.de
Betreff: Re: [Mapserver-users] Raster layer and Projection
Frauke,
Please please please set "STATUS DEFAULT". This is a "rite de passage"
every MapServer user has to go through. Is there any kind-hearted person
who can explain why we need STATUS DEFAULT in addition to STATUS OFF and
STATUS ON? If you want to set layers on via the URL, you can just as
well use STATUS OFF in the MapFile.
Jan Hartmann
frauke.trurnit at gmx.de wrote:
> Hello list,
> I've some problems with rasterlayer. I hava a 8bit-tif and a tfw world
file
> in the same directory. In the Browser however no map appears. What's wrong
> with the mapfile?
> In addition an error message appears in the Browser, if I use the
> projection indicated down.
> Error message:
> msProcessProjection(): Projection library error. unknown projection id
> The world file looks like that:
     this worldfile is correct- 6 digits before the decimal point is o.k.
> 1.00000000000000000
> 0.0
> 0.0
> -1.00000000000000000
> 509854.76027950307
> 5408094.4232678544
> My mapfile:
> STATUS ON
> UNITS dd
> SIZE 500 500
> IMAGETYPE GIF
> #PROJECTION
> #   proj=UTM
> #   ellps=WGS84
> #   datum=WGS84
> #   zone=32
> #   north
> #   no_defs
> #END
> WEB
> END
> #LAYER
DEFINITIONEN---------------------------------------------------------
> LAYER
>   NAME "Stuttgart"
>   DATA "stgt_d7517_unk.tif"
>   TYPE Raster
>   STATUS ON
> END
> END #mapfile
> Frauke Trurnit
Jan Hartmann
Department of Geography
University of Amsterdam
jhart at frw.uva.nl
+++ GMX - Mail, Messaging & more  http://www.gmx.net +++
NEU: Mit GMX ins Internet. Rund um die Uhr für 1 ct/ Min. surfen!
