[Mapserver-users] instruction : mapserver on Mandrake 9
Gerald G. Villacarlos gerald at cvis.net.ph
Thu Dec 12 21:55:24 EST 2002
thanks alot!, im working on that already..ill be back as soon as im done with this one....
-gerald
> On Thu, 2002-12-12 at 10:41, Gerald G. Villacarlos wrote:
> > hello list
> > is there a link on how to intall mapserver on a Mandrake 9 box..
> > suggestions are very much welcome since i badly needed it ...
> As far as I know Mandrake Linux is based on RedHat linux. I'm working
> myself on a (slightly extended) Mandrake 9 installation, and if I
> remember well I basically followed the unix installation guide (see the
> documentation section on the mapserver homepage, section
> mapserver3.6->unix compilation and installation howto, and the RH
> install guide (rather basic) on the wiki pages
> (http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?LinuxBuild). Usually, for
> me the trouble is not in compiling and installing mapserver, but in
> getting all needed/wanted libraries compiled and linked with mapserver.
> I'd say, have a look at the unix install guide (it tells you about all
> possible/needed libraries etc., and don't forget to compile a separate
> php binary to use as a cgi instead of the standard apache-extension php
> usually is...) and give it a try. And when you get troubles compiling
> something or getting things to work, or simply feel the need for more
> detailed answers, don't hesitate to post a message.
> Good luck!
> Vincent Schut,
> SarVision B.V.
> > regards.
> > gerald
> > System Administrator
> > GEOPLAN Cebu Foundation, Inc.
> > DOST-7, M. Cuenco Ave. Cebu City
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
