[Mapserver-users] mapscript python
Sven Jacobi
jacobi at dfki.de
Mon Dec 16 10:19:33 EST 2002
On Mon, Dec 16, 2002 at 03:56:57PM +0100, Sven Jacobi wrote:
> Hello Vinko,
> first off all, thanks for your attention.
> To your questions:
> - I have used STATUS DEFAULT and I still get the BUS ERROR
> - I have a world file ( *.tfw) but do I have to "mention" it
> or does mapscript reference it automatically?
> - The image is in 8 bit color
> - with "not working" I mean, I get a "Bus Error" in Python, but I can't
> get any BUS ERRORS in Python so I thought it depends on the C-library
> - what do you mean exactly with blank according to blies.png?
> - Only the vector layers in blies.png?
> When I try to use it over CGI without mapscript everything works fine...
> Any further ideas where this might come from?
If it works with the CGI version I guess you need to dig deeper in the C
code of MapServer/MapScript :(
The Python release is not as actively maintained as PHP/Perl versions,
so there might be a change in the code that broke something in the
Python version (Shouldn't SWIG take care of that?)
You could try running a PHP or Perl script analogous to yours to discard
some possibilities.
At what point does it break, at saveImage, draw, or before?
PS: Try replying to the list as well, because 'given enough eyes, all
bugs are shallow' :)
Hello, once again!
It breaks down exactly at the call to draw...
I also thought that SWIG would do this for me but it doesn't seem so :(
Do you know whether it is possible to run a logfile for mapscript?
Cheers,
Sven
