[mapserver-users] Initial pre-alpha release of the CLX component for Delphi
Pedro A. Carrasco pcarrasco at iver.es
Tue Jan 8 10:11:10 EST 2002
    To make the VCL is not very complicated, the CLX components I use in the
control are TImage and the control to make the html petitions, but this one
is from the Indy components. Other CLX units (like QGraphics, QControls) are
replaceable but the same in VCL (Graphis, Controls, etc).
    Regards
Pedro A. Carrasco Ponce
IVER Sistemas de Información Geográfica
Dpto. Técnico
C/Salamanca, 50
46005 Valencia
Tlf: 96 316 34 00 Fax: 96 316 2716
mail : pcarrasco at iver.es
web : http://www.iver.es
----- Original Message -----
To: "'Pedro A. Carrasco'" <pcarrasco at iver.es>
Sent: Tuesday, January 08, 2002 2:20 PM
Subject: RE: [mapserver-users] Initial pre-alpha release of the CLX
Hi Pedro
Do you have any plan to make a VCL ?
I have developped a couple of mapserver client in Delphi
(see
http://www.cgq-qgc.ca/hydrolink/public/mapservice/cgknmapView.html)
is it something similar ?
> -----Original Message-----
> From: Pedro A. Carrasco [mailto:pcarrasco at iver.es]
> Sent: 8 janvier, 2002 07:24
> To: Lista MapServer
> Subject: [mapserver-users] Initial pre-alpha release of the CLX
>     Hi all,
>     I'm developing a CLX component to access MapServer from Delphi
> Applications, my intention is to make a component similar to
> MapObjects
> (only similar, not the same, more like MapObjects LT), but
> working with the
> MapServer enviroment. I develop it in Delphi beacouse it can
> compile in
> Kylix (Linux). The pre-alpha release can be downloaded from
> http://www.polaris2000.net/_temp/mapserverdelphi.exe it only
> make zoom in,
> zoom out, and pan (and full extent), it have two directories,
> one with the
> clx control and the other with the sample aplication I use,
> tha application
> is code linked with my .map file and layers, this code can be
> changed for
> the use with others .map and layers.
>     I hope it will be usefull.
>     Regards.
> Dpto. Técnico
> C/Salamanca, 50
> 46005 Valencia
