[mapserver-users] Installation Problem: Black Screen
Harahap, Zuki
Zuki.Harahap at conoco.com
Wed Jul 3 02:36:24 EDT 2002
I faced this problem last week as first time user. On your
demo_init.html file, check the line contain imagepath and imageurl. It
should point to correct directory (create if not exist and check the
permissions as suggested by Filak below.
Zuki
-----Original Message-----
Sent: Tuesday, July 02, 2002 11:14 PM
To: Isai Michel
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] Installation Problem: Black Screen
What are the permissions and ownership on the /tmp directory?
On Tue, 2 Jul 2002, Isai Michel wrote:
> Hello:
> I am running a Suse 8.0 linux machine and have installed map server.
I
> compiled the files and everything seems to work fine except that when
I run
> the demo test, I get to the template file and their is a big black
spot
> where the map picture should have been rendered. And yes, I turned
the gif
> files into png files. Oddly, you can right click the image and choose
to
> save it but when you try to actually save the map pictures (in PNG
format)
> the computer says the file does not exist. The /tmp directory
(relative to
> the top level domain) is also empty.
> Can someone please tell me how to get it to work? I have spent
several days
> reading all the documentation. Thank you very much.
> Respectfully,
> IML
