[Mapserver-users] Looking for mapserv
Howard Mark
MHoward at spaceimaging.com
Fri Apr 18 10:45:41 EDT 2003
I'm looking for a mapserv.exe is like:
INPUTS: GDAL, OGR, SHAPEFILE
SUPPORTS: PROJ, WMS_SERVER, WMS_CLIENT
OUTPUTS: GIF, PNG, JPEG
The current win32 binaries have a problem with the JPEG library versions.
I'm not even using JPEG input - but the WMS connector does and won't work
with this version. I'd like to be able to hook up to an OGC/WMS data source
and also SDE.
TIA,
Mark
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
