[Mapserver-users] which ./configure options needed?
Benjamin Thelen benjamin.thelen at ccgis.de
Fri Apr 25 08:35:30 EDT 2003
Hi Frank,
at least gdal and ogr is no problem, but I have a three other problems. One
with php, proj4 is not recognized and I don't have a jpeg library. I'll post
these as reply to Jean-Francois Doyon's mail.
Thanks,
Benjamin
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Frank
> Warmerdam
> Sent: Tuesday, April 22, 2003 9:28 PM
> To: Benjamin Thelen
> Cc: UMN MapServer
> Subject: Re: [Mapserver-users] which ./configure options needed?
> Benjamin Thelen wrote:
> > I would like to start compiling, but I am quite unsure what
> options for the
> > configure-skript I have to take, because it is written in the mapserver
> > documentation that "Some libraries will NEVER be detected by
> default, and
> > HAVE to be specified via the configure script". That would mean
> to me that I
> > only have to take those options
> > --with-proj, --with-ogr, --with-gdal, --with-wmsclient (I don't
> need mpatrol
> > and sde), which are never detected and the rest will be detected
> > automatically. But somehow I think, I am wrong ;-)!
> > If ogr is part of gdal, why do I have to specify ogr seperately? I don't
> > know how to specify the correct path to the installed software because,
> > there are so many libraries installed with the software. If I
> had a specific
> > file I would have to specify, no problem, but application path...?
> Benjamin,
> If you are including GDAL (--with-gdal) it should be sufficient to list
> --with-ogr to get OGR too.  You shouldn't need to include any path.  GDAL
> does include a gdal-config script which I think you can point to with the
> --with-gdal switch.  The configure will then run gdal-config to get the
> necessary link and include options, much like GTK for instance.
> BTW,
> Good luck,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
