[Mapserver-users] MS 3.7 and RH 8 woes
Lowell Filak lfilak at medinaco.org
Wed Mar 5 11:28:38 EST 2003
Hmmm...
Can you send the whole script?
Lowell F.
The following message was sent by Gerry Creager <gerry.creager at tamu.edu> on Wed, 05 Mar 2003 10:20:58 -0600.
> Lowell,
> Thanks.  It all helps, even if it's not fixing the problem.  At least
> I'm starting to get a better handle on this stuff!
> This is is what I had:
> my $shape = new shapeObj($mapscript::MS_SHAPE_LINE);
> Replaced with:
> my $shape = new mapscript::shapeObj($mapscript::MS_SHAPE_LINE);
> And it yielded the same error.  I'm sure it's someting fundamental.  I'm
> just _lost_ at this point.
> TIA, gerry
> Lowell Filak wrote:
> > If you currently have something like:
> > my $shape = new shapeObj(-1);
> > try replacing it with:
> > my $shape = new mapscript::shapeObj(-1);
> > HTH
> > Lowell F.
> > The following message was sent by Gerry Creager N5JXS <gerry.creager at tamu.edu> on Wed, 05 Mar 2003 07:47:40 -0600.
> >>Sorry for the newbie questions:  I should have kept up with the
> >>technology myself instead of letting a graduating grad student get ahead
> >>of me!
> >>I've got the nightly build from Sunday evening compiled, sans errors,
> >>and installed per Steve Woodbridge's Wiki entry.  That part seemed to go
> >>great.  Excellent step-by-step directions, no problems.  I took no
> >>shortcuts there to get anyting going.
> >>However, perl mapscript is DOA. I'd tried a CVS load that didn't even
> >>come close to allowing me to compile perl-mapsecript, thus the nightly
> >>download, which at least allowed compilation.  So that's working.
> >>Now, however, when I attempt to run a perl script that calls
> >>perl-mapscript, I get the following:
> >>[root at vne-dhcp-047 mesonet]# ./makeshapefile.pl
> >>Name "mapscript::MS_SHAPEFILE_POLYGON" used only once: possible typo at
> >>./makeshapefile.pl line 22.
> >>Name "mapscript::MS_SHAPE_LINE" used only once: possible typo at
> >>./makeshapefile.pl line 175.
> >>Can't locate object method "new" via package "shapefileObj" (perhaps you
> >>forgot to load "shapefileObj"?) at ./makeshapefile.pl line 22.
> >>makeshapefile.pl worked on 3.6.3 on a RH7.3 install with perl v5.8.0.
> >>I've gotten XBase and DBD loaded, and mapscript installed in the
> >>appropriate place.
> >>If it helps, here's the output of mapserv -v:
> >>[root at vne-dhcp-047 mesonet]# /var/www/cgi-bin/mapserv -v
> >>MapServer version 3.7 (development) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> >>OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
> >>SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=GD2_RGB INPUT=OGR
> >>INPUT=GDAL INPUT=SHAPEFILE
> >>Any advice greatly appreciated!
> >>Gerry
> >>Gerry Creager -- gerry.creager at tamu.edu
> >>Texas Mesonet -- AATLT, Texas A&M University
> >>Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
> >>Page: 979.228.0173
> >>Office: 903A Eller Bldg, TAMU, College Station, TX 77843
> >>_______________________________________________
> >>Mapserver-users mailing list
> >>Mapserver-users at lists.gis.umn.edu
> >>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Network Engineering -- AATLT, Texas A&M University
> FAX:  979.847.8578 Pager:  979.228.0173
