[Mapserver-users] E00 to SHP Conversion Utilities?
Lowther, David W dlowther at ou.edu
Thu Mar 6 14:01:11 EST 2003
Dan,
The utility IMPORT71.exe that comes with Arcview is made for this... I'm not
sure if it is available freely or not.
If you just have a couple of files Dan send em my way and I'll convert for
you.
Dave
> -----Original Message-----
> From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> Sent: Thursday, March 06, 2003 10:01 AM
> To: Dan Barron
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] E00 to SHP Conversion Utilities?
> Dan Barron wrote:
> > Does anyone have a suggestion on the best approach to convert E00
> > files to SHP files?  I have tried the FME Suite from Safe
> Sowftware,
> > are there other available tools/utilities to accomplish this
> > conversion?
> FME is definitely the best option, but the license may be expensive.
> Unfortunately OGR doesn't support reading E00 files yet,
> otherwise using ogr2ogr would be a good option too.  I'm sure
> many GIS packages will allow import of E00 and export to
> shapefiles, but I don't have any to suggest.
> However, OGR (GDAL 1.1.8) does support reading binary
> coverages, so you can do the conversion in two steps if you want:
> 1- Convert your E00s to binary coverages using the
> 'AVCIMPORT' utility at
> http://pages.infinit.net/danmo/e00/index-> avce00.html
> 2- Use
> 'ogr2ogr' (part of GDAL 1.1.8) to
> convert the binary coverages to shapefiles.  There should be
> some docs on using ogr2ogr on the OGR website at
> http://gdal.velocet.ca/projects/opengis/index.> html
> Daniel
>  Daniel Morissette               morissette at dmsolutions.ca
>  DM Solutions Group              http://www.dmsolutions.ca/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
